| wjdashwood |
| Posted: Jun 25 2003, 07:46 PM |
I can't see that this has been posted before but sorry if it has already been brought to light.
I think I've found a bug in VDM 1.5.1.1a. Disabling an audio stream doesn't seem to work when saving the job for batch mode. It works fine if I just disable the stream and immediately save to a new file but I frequently like to re-encode a MPEG file with DivX, disable the original audio stream on both the first and second passes and then add an Ogg Vorbis stream on the second pass. It used to work fine before the recent major changes (streams menu) but now I end up with the original audio stream uncompressed resulting in very large files!
Hope it’s not just me and that this is actually a bug. If not, any suggestions as to what I’m doing wrong are welcome
Thanks, Will |
| Suiryc |
| Posted: Jun 25 2003, 08:29 PM |
Developer of VirtualdubMod
Group: VirtualdubMod Team
Do you use the latest bugfix released ? This bug should be fixed by now.
| wjdashwood |
| Posted: Jun 26 2003, 01:34 PM |
Ah, didn't even notice that at the bottom of the page. I'm pretty sure that has solved it.
Cheers, Will |
