| Neighbour |
Posted: Mar 28 2003, 12:06 AM |
Upon starting up the executable, the infamous "illegal operation"-box pops up.
Installation procedure : copy original vdub1.4.13 dir to vdubmod1.4.13.2, unzip VirtualDubMod_1_4_13_2.zip into that dir, overwriting everything.
OS information : Win98SE, Dx9, need more? System information : Asus a7v133 w/ Tbird1200@1200, 512MB ram.
Crash info : (copied from the errorbox), dunno if it's of any use, but it doesnt hurt (much to put it here.
VIRTUALDUBMOD caused an invalid page fault in module VIRTUALDUBMOD.EXE at 019f:0046408e. Registers: EAX=0177fe48 CS=019f EIP=0046408e EFLGS=00010246 EBX=00000000 SS=01a7 ESP=00c8f554 EBP=00c8f560 ECX=00000013 DS=01a7 ESI=0177fe4e FS=3257 EDX=0057ac50 ES=01a7 EDI=00518d98 GS=0000 Bytes at CS:EIP: f3 a6 75 07 8b 48 40 8d 44 01 48 80 38 5b 75 66 Stack dump: 0057ac50 0057aca0 004ca2a0 00c8f6e8 00463f6b 0057ac50 0177fe48 81a67928 81a72e44 00000000 0057aca0 000b0a00 004ca2a0 00000100 004ca32f 01580000
I have plenty of dxshow-filters installed (no codec packs), no problems with prior versions of vdub and the initial release of vdubmod (VirtualDub-1.4.13-MPEG2-AC3.zip) were encountered.
Please advise |
| ChristianHJW |
| Posted: Mar 28 2003, 08:04 AM |
There was a stupid bug, its fixed now, get the latest version from download page ...
| Neighbour |
| Posted: Mar 28 2003, 08:51 AM |
Check, 4.13.2v2 has the issue fixed. Thanks guys |
