Encoding Ogg In Vdubmod
Jared
Posted: Mar 2 2003, 01:33 PM
Is it possible to encode the audio in my projects with ogg, directly in VDM? Like from where I can choose to encode in mp3, and the bitrates, etc... is there a way to use ogg?
Also, why is it that the 2nd audio has many more bitrates available for encoding than the 1st one?
The 1st question is very important to me, the 2nd is just curiousity smile.gif
-Jared
Devilman
Posted: Mar 2 2003, 04:52 PM
Right now you can't encode a ogg audio within VirtualDubMod because there isn't an Ogg codec but only a DirectShow filter, so you have to code it externally with BeSweet for example.
For the second question I'm not sure if I understand right when you ask for compress an audio you see two Mpeg layer 3 menu with different bitrate, this is normal if you have installed the radium codec, because the first one with very few bitrate is the one that come with Windows the second one is the one installed with the radium codec.
Hope I understand right and this help.
Bye
Devilman
Neo Neko
Posted: Mar 4 2003, 09:57 AM
VirtualdubMod Alpha tester
What about Freddie Fish's Vorbis ACM? It should work although you may not get the best possible results.
Devilman
Posted: Mar 4 2003, 05:01 PM
@ Neo Neko
I don't know this one, if you can post a link I'll give it a try and I will let you know.
Bye
Devilman
3 replies since Mar 2 2003, 01:33 PM Track this topic | Email this topic | Print this topic
