| CentralPlexus |
| Posted: Feb 4 2003, 05:38 PM |
I have a Xvid encoded File, chrashing every Player and VirtualDub at precisely the same time. Removing Junk didn't help. Opening the file with option >re-derive keyframe flags< crashes VirtualDub 1.4.13 (14328) saying "Integer Divided-by-Zero" and sometimes it crashes saying something about MMX: "Internal error: MMX state left on: T:\projects\VirtualDub_old\main\VideoSource.cpp:1630"
Can anybody help me - or am i just too stupid to use it properly
Thx |
| Pamel |
| Posted: Feb 4 2003, 11:31 PM |
matroska team member
Is it a copy of The Two Towers? I saw one like that and replacing installing the latest ffvfw helped out. It was able to handle being passed the corrupted frames, and rendered frames (albeit frames with corruption).
If that works, then you can re-encode just those portions of the file that were corrupted, and then the file will play anywhere.
-------------------- Please take anything I say with many many grains of salt. I can't tell the difference between my AVI and a hole in the ground. |
