Portability Of Mjpeg Decoding Code
jcsston
  Posted: Aug 13 2003, 06:47 PM
Matroska Dev
How portable is the MJPEG decoding code in VirtualDub?
Would it be too much work for me to change it to compile with Linux/GCC? or would using some existing Linux code be better?
Use the Matroska file format
Posted: Aug 14 2003, 07:44 AM
You could probably get the C++ core to compile with gcc with some minor elbow grease, and the asm could could be adapted to NASM. The inline assembly color conversion cores will give you some trouble but they are fairly easy to lift out. There's certainly nothing in the MJPEG core that is specific to Windows... oh wait, did I use the stack pointer as a general purpose register? I don't remember. ^^;
jcsston
  Posted: Aug 15 2003, 09:47 PM
Matroska Dev
Thanks, I don't know ASM so I will have find some other MJPEG decoding code.
Posted: Aug 16 2003, 04:57 AM
QUOTE (jcsston @ Aug 15 2003, 05:47 PM)
I don't know ASM
You don't know what you're missing. The glory, the agony, the bliss, the tears. I don't know if it's an art or a religion, but somehow no other language can compare with Assembly. ASM forever... cool.gif
3 replies since Aug 13 2003, 06:47 PM Track this topic | Email this topic | Print this topic
