| PopjeLove |
| Posted: Oct 21 2009, 04:14 PM |
I get this message.. Unable to initialize the output video codec. check that the video codec is compatible with the output video frame size and that the settings are correct, or try a different one.
I dont now what to do..!! Plz help..
I try to get a subtitle under a Avi file.. With evry movie it works, only not with this one.. =( |
| Posted: Oct 22 2009, 04:14 AM |
Usually this means that the codec can't accommodate the frame size -- which is commonly the case if the width or height aren't multiples of 8. |
