Hi guys,
the latest matroska packs are online at the usual place on http://packs.matroska.org now. The last packs ( 1.0.2 ) were loaded about 300,000 times since April, creating about 750 GB of traffic in total.
Latest changes are
- The packs are now using the latest version of ffdshow, but a special version without encoder ( only decoder ). This means that now all newer XviD movies will play fine also
- Latest matroskasplitter from Gabest's Guliverkli site is used, 1.0.2.4, and it will support new MKV files created with very latest mkvtoolnix ( 0.9.5 ) with higher timestamp precison ( 64 bit )
- A dshow decoder and encoder filter for the new TTA lossless audio format was added
- Latest matroska muxer filter, also from Gabest, is included
- The pack will check if a decoder DLL for Realvideo 9 is installed, and come up with a warning that MKVs with RV9 will not play if not, and point to Realplayer or Realcodec.exe to get this decoder
- Also all other filters were updated to their last versions, like DVobSub ( vsfilter ), Morgan Stream Switcher ( mmswitch, deactivated by default ), Matrix Mixer ( also deactivated ), AC3filter, CoreVorbis, CoreFLAC, CoreAAC, etc.
Have fun !
Christian matroska project admin http://www.matroska.org http://packs.matroska.org
