Virtualdubmod 1.5.10.1 Released
Suiryc
Posted: Dec 3 2003, 09:23 PM
Developer of VirtualdubMod
Group: VirtualdubMod Team
As the subject say.
The changelog (not as long as in previous releases tongue.gif)
[VirtualDubMod 1.5.10.1]
Cyrius:
- Warn you when a subtitle don't have its duration set in a matroska file (instead
 of throwing an error).
- Warn you if something really bad about timecodes happens when writing an mkv file.
- Fixed bug (1.5.4.1) where all streams would be muxed with a 1 frame interleaving.
- Fixed bug (1.5.4.1) where Matroska Segment size was incorrectly written.
- When editing an mkv file (without recompressing) the Aspect Ratio info is kept.
- Fixed bug where some large (>4GB) files wouldn't open.
- Fixed bug where the length of uncompressed audio streams would be wrong for OGM/MKV files.
- Fixed bug preventing Win 9x/Me users from saving sequence of images.
- Using Advanced filtering on more than one audio stream should work properly now.
- Fixed yet a few crashes when processing badly corrupted OGM files.
- Fixed bug where chapter information were incorrectly processed when muxing (would happen
 when deleting a subset starting at frame 0).
- Fixed possible crash when processing corrupted MP3 VBR stream muxed in an AVI file by
 Nandub or (really) old versions of VirtualDubMod.
- Fixed problem with AVI files containing an MP3 stream encoded using Dr. DivX.
- Fixed possible problem with AVI files containing MP3 VBR muxed with AVI-Mux GUI.
- Fixed problem (error -100, no video appearing in the preview windows) where XviD was
 selected as decoder (instead of DivX) with OGM/MKV files containing DivX 5 video.
- Fixed broken code (resulting in problems when opening or muxing) in the DTS parser.
- Take into account the LFE channel in channel count for AC3 files.
- Readded the possibility to enqueue "Save WAV" or "Demux" as a job.
- Stream title is now written as stream name in AVI files.
- Copied VirtualDub 1.5.5 code to fix the focus stealing issues with the "Dubbing Status"
 window. Also now this window remains hidden when using the /s commandline option.
- Fixed bug where some mkv files (with incorrect segment size) wouldn't open.
- Fixed bug preventing the "Audio" menu to popup under Windows NT4.
- Merged changes up to 1.5.10. Expect new exciting bugs now :>
- Removed ASF support in the code. There are better tools out there for ASF.
- Removed internal AC3 decompressing since fccHandler made an ACM codec for AC3.
- Added an option ("Adjust chapters ...") for chapters inside a stream. When enabled the
 chapters time are adjusted according to the subsets (i.e. the chapters listed for a stream
 are considered as the ones for the original full clip). When disabled the chapters are
 only adjusted according to the start and end time of your selection (i.e. the chapters
 listed are considered as the ones of the clip after you edited subsets).
- Warning (instead of errors) are triggered for some errors (when some data had no timestamp,
 or when a frame had only a forward reference) inside Matroska files.
- A warning should be triggered when a VFR video stream is found inside a Matroska file.
 Nb: in this case we strongly advise you to use another tool to safely process your file.
- Removed VDM specific items from the 'standard' preference windows. Use the 'VDubMod'
 preferences window to setup those settings.
- Added a (track) "Name" comment in the availabe comment types. This set the track name in
 AVI files (only shown by some players) and correspond to the track name in Matroska.
Belgabor:
- Included Toff's fix for the last chapter in matroska files.
- Added 'Insert Crop' in the Script Editor for AviSynth scripting. It sums up all
 crops performed in the VDub filters.
- Two new options for the Script Editor. One activates single instance mode meaning
 you will only have one editor window. The other one automatically pops up the script
 editor when you open an avs file or loads it into an active editor window in single
 instance mode.
- Fixed: Refresh [1.5.9]
- Fixed: Frameset transfer to AVS Editor [1.5.9]
- Fixed: Hotkeys in AVS Editor [1.5.9]
- Converted filename transfer to unicode.
- Partly fixed: AVS Templates (no unicode filenames and no multiple selection yet) [1.5.9]
- AVS Templates are now a part of the normal Open Dialog, replacing "Open via Avisynth".
- Fixed: tick settings not working if a file is opened via the MRU
As usual on SourceForge.
Many important changes have been made in the code of VirtualDub since last release. So there may be many stupid bugs remaining ...
Enjoy
Suiryc
Posted: Dec 10 2003, 12:09 AM
And already a bugfix version :
Cyrius:
- Fixed: (1.5.10.1) an input file containing audio would remain opened even
 after "Clode video file" (thus preventing from deleting the file).
- Fixed: (1.5.10.1) crash when starting capture.
- Fixed: (1.5.10.1) ticks in the trackbar. Now have the same behaviour than
 VirtualDub (when in "Frames" mode).
- Fixed: (1.5.10.1) not enough space was reserved for the KaxSeekHead at the
 beginning of Matroska files. Added warnings (logs) when this happen.
- Fixed: duplicated references when writting 2 KaxSeekHead in Matroska files.
- Fixed: (1.5.10.1) logs shown 2 times when saving a Matroska file.
- Fixed: issues when decompressing AC3 (1.5.10.1) or audio using ACM.
- Fixed: issue with the input audio filter (graph) that would stuck the dubbing.
Suiryc
Posted: Mar 9 2004, 02:53 PM
Another bugfix is available (build 2439).
Fixes other bugs (especially the speed issue introduced in 1.5.10.1).
FievelMousey
Posted: Apr 26 2004, 03:15 PM
Hi can you tell me where to download this new build you say is out i have looked all over site for it and have not been able find it?
Thanks
Suiryc
Posted: Apr 27 2004, 01:28 PM
On sourceforge.
Here is the initial 1.5.10.1 version that you need to get first.
Then here is the bugfix version (build 2439) that contains 2 updated files (.exe and .vdi).
rambo420
Posted: Jul 7 2004, 03:56 AM
so will the latest version of VirtualDub be able to covert OGM files and MKV files.??? Cause when I try to covert and OGM file it gives me an error huh.gif
ChristianHJW
Posted: Aug 3 2004, 11:51 AM
Dont mix up Virtualdub and VirtualdubMod ....
6 replies since Dec 3 2003, 09:23 PM Track this topic | Email this topic | Print this topic
