Pages: (3) 1 [2] 3  ( Go to first unread post )
Fairly Quick Filter Multiadjust, Brightness, contrast, saturation, hue...
John I.
Posted: Jul 31 2010, 07:28 PM
This is your filter, and you decide how you want it. I only offer ideas and suggestions (I believe that the nature of the forum is to exchange ideas and opinions for improvement and not only to complain about bugs or deficiencies.)
One more suggestion:
As the settings in the filter are dependent on visual adjustment, the preview could be enabled by default, and the 'show/hide preview' button could be removed to save space for other controls.
Posted: Jul 31 2010, 08:27 PM
I've no problem with suggestions and ideas :-)
V0.15 removes preview button and opens preview window automatically
My mind rebels at checkboxes for enabled and half-enabled
But that's because I'm looking at it and an annoying pedantic voice at the back of my head is going
Disabled? AND half-enabled... all at the same time eh.... hmmmm???
I'm so used to being able to chop and change things I want altering that it seems odd to consider that other people are getting-what-they-are-given
You should see my vdub mod, it's never the same program 2 days running dry.gif
John I.
Posted: Jul 31 2010, 08:47 PM
Then, maybe a button for 'enable' and a drop list for 'Full/Half preview.' smile.gif
I get what you mean, but what I meant is, these are two types of functions:
1. Partial setting: Type of preview (Full/Half.)
2. All settings (Active/Not Active.) only two states, there is no 'half-enabled'
Posted: Jul 31 2010, 08:56 PM
QUOTE (John I. @ Jul 31 2010, 08:47 PM)
Yeah, I'll look at that tomorrow
Disable the combo when unchecked etc...
John I.
Posted: Jul 31 2010, 09:08 PM
dloneranger,
V0.14 is fine with me. If the drop list combo could be rearranged from
-Show Effect
-Half frame
-Disable Effect
to
-Show Effect
-Disable Effect
-Half frame
that would do it.
Having 'Half frame' between 'Show' and 'Hide' is somehow distracting for eye comparison across the whole frame.
Posted: Jul 31 2010, 09:31 PM
Hmmm, thought I'd done that in .15 already
[edit]
No, I'd moved them around to
disabled
enabled
half
with enabled selected by default
I'll look at it tomorrow though
John I.
Posted: Jul 31 2010, 10:20 PM
I think I like the order you provided. This way, you can go either way with just one roll of the wheel.
Posted: Aug 1 2010, 04:00 PM
Updated V0.16
Cosmetic update
Moved some controls
Added Help and About buttons
Posted: Aug 1 2010, 06:40 PM
Updated V0.17
Serious bugfix for error introduced in V0.15
This would cause queued jobs to bypass the filter
V0.1.7
Bugfix
Silly mistake(after moving preview options around) saved jobs had the filter disabled - my bad
Posted: Aug 23 2010, 09:49 PM
Update V0.1.8
Added
Experimental highlight reduction
Lets you tone down only overbright video eg flash glare on faces
Select how narrow a range of brightness to affect, reduction amount and pre/post brightness adjustment
It's a bit tricky as the results can vary from extremely subtle to foully hideous
Gromozeka
Posted: Sep 2 2010, 12:41 PM
good filter
Posted: Sep 2 2010, 01:01 PM
The configuration dialog's a bit big, but that does mean you can use all the options at the same time and it doesn't get slower
Gromozeka
Posted: Sep 2 2010, 06:31 PM
QUOTE (dloneranger @ Sep 2 2010, 01:01 PM)
cool.gif Yes - a good realization for us
Posted: Sep 24 2010, 09:53 AM
By req
V0.19
Added checkbox for saturation to only affect red's
OPODER!!!
Posted: Oct 7 2010, 03:40 PM
Man, really good filter!
I like Half Frame. Good to compare.
But be carefull. Because new filters/utilitys/application use BIG Window / BIG Buttons / BIG Bars... and its not good for whom use 800x600 resolution (yes many, like me, use it).
Thank you for your filter.
And SORRY about my english
39 replies since Jul 14 2010, 03:21 AM Track this topic | Email this topic | Print this topic
Pages: (3) 1 [2] 3
