| Placio74 |
| Posted: Jul 7 2009, 04:26 AM |
VideoAudio
@hayamiya A guess that you do not know what is MediaInfo...?
| hayamiya |
| Posted: Jul 7 2009, 02:15 PM |
| QUOTE (Placio74 @ Jul 7 2009, 05:26 AM) | @hayamiya A guess that you do not know what is MediaInfo...? |
For files like flv, no, I only use GSpot for avi/mpeg files.
Thanks Placio
EDIT: I forgot Thanks for the answer Moitah. It's a shame :/ I think I'll open YouTube files with the url fmt=18. Less quality (they are 500kbps against new ~900kbps flvs), but at least they are MP4 and then, editable. (I don't know if your app flvextract works as I don't use .NET framework apps) |
| Placio74 |
| Posted: Jul 7 2009, 03:24 PM |
VideoAudio
| QUOTE (hayamiya @ Jul 7 2009, 04:15 PM) | ... EDIT: I forgot Thanks for the answer Moitah. It's a shame :/ I think I'll open YouTube files with the url fmt=18. Less quality (they are 500kbps against new ~900kbps flvs), but at least they are MP4 and then, editable. (I don't know if your app flvextract works as I don't use .NET framework apps) |
Hovewer... can change container (FLV>MP4) used FFmpeg (just copy A/V to MP4) - after, eventually re-mux (MP4>MP4) used MP4Box (Yamb) to complete certain properties.
| hayamiya |
| Posted: Jul 7 2009, 04:26 PM |
Thanks for the tips but... long process for few files that I want to, eventually (too), edit and save to my hard drive
Thanks anyway |
| Placio74 |
| Posted: Jul 11 2009, 01:00 PM |
VideoAudio
| QUOTE (hayamiya @ Jul 7 2009, 06:26 PM) | | ... long process for few files that I want to, ... |
This is not a long process - because A/V is simply copied to another container.
| DVJ Rick Kraft |
| Posted: Feb 26 2010, 01:23 PM |
hayamiya: it's not necessary, you CAN open AVC(h264) with AAC in Virtualdub!
MediaInfo // Test file: D:\TEST VIDEOS\Three 6 Mafia Feat. Tiesto, Flo Rida & Sean Kingston - Feel It.flv Format : Flash Video File size : 25.3 MiB Duration : 4mn 30s Overall bit rate : 784 Kbps
Video Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L3.0 Format settings, CABAC : Yes Format settings, ReFrames : 3 frames Muxing mode : Container profile=Unknown@3.0 Duration : 4mn 30s Bit rate : 659 Kbps Width : 490 pixels Height : 360 pixels Display aspect ratio : 4:3 Frame rate : 29.970 fps Resolution : 8 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.125 Stream size : 21.2 MiB (84%)
Audio Format : AAC Format/Info : Advanced Audio Codec Format version : Version 4 Format profile : LC Format settings, SBR : No Duration : 4mn 30s Bit rate : 117 Kbps Channel(s) : 2 channels Channel positions : L R Sampling rate : 44.1 KHz Stream size : 3.76 MiB (15%)
http://i162.photobucket.com/albums/t243/pi...flvtestcrop.jpg
-------------------- AMD Phenom X4 B55@3.83Ghz aircool (unlocked X2 555,),4GB DDR3@1650mhz GA MA785gpmt-ud2h, 16GB SLC SSD (164MB/s burst, 150 avg) windows 1TB RAID0(380MB/s burst, 217 avg) processing, 1.5TB (228MB/s burst, 108 avg) Synology DS110j 1.5TB NAS |
| Placio74 |
| Posted: Feb 26 2010, 07:18 PM |
VideoAudio
| QUOTE (DVJ Rick Kraft @ Feb 26 2010, 03:23 PM) | | hayamiya: it's not necessary, you CAN open AVC(h264) with AAC in Virtualdub! |
Rather, using 'DirectShow import driver' plugin - but not directly (and not through FLV input plugin)...
| DVJ Rick Kraft |
| Posted: Feb 27 2010, 06:35 AM |
| QUOTE (Placio74 @ Feb 26 2010, 07:18 PM) | Rather, using 'DirectShow import driver' plugin - but not directly (and not through FLV input plugin)... |
I suppose it may use the Import Driver, although to be honest, i never have to select it, it's simply drag n drop, which made me think I have the correct VFW codecs to handle it (using ffdshow).... ? Anyways, it does work!
| Placio74 |
| Posted: Feb 27 2010, 07:17 AM |
VideoAudio
| QUOTE (DVJ Rick Kraft @ Feb 27 2010, 08:35 AM) | I suppose it may use the Import Driver, although to be honest, i never have to select it, it's simply drag n drop, which made me think I have the correct VFW codecs to handle it (using ffdshow).... ? Anyways, it does work!  |
So, I guess you do not have FLV input plugin, because then FLV files would be handled by him (as default).
DirectShow import driver does not 'use' VfW codecs, but just DirectShow filters. And of course it's external plugin - VirtualDub does not include this plugin by default.
DirectShow import driver handle any file type (that can be played through DirectShow, in WMP for example) and any file extension which is not supported by VD or other input plugins.
However, to open file with extension supported by VD or other input plugins (present in subfolder plugins) by DirectShow import driver, you must manually 'select' this plugin (when open A/V file).
| trodas |
Posted: Dec 26 2012, 09:52 PM |
A little bugreport. Trying to look at this video: http://www.youtube.com/watch?v=A7IvLEpjPmc
...downloaded from YewTube by save2PC Utimate as highest quaity w/o recompression (FLV format) and when trying to open it into VirtualDub, it says: File "D:\Recipe for a Revolution.flv" does not have a video stream."
Damn. Using the VirtualDub 1.9.11 and FLVInputDriver.vdplugin v1.1.0 by Moitah... hope it does not require the .NET framecrap I just wanted the audio from the file...
Sample to test is there: http://www.sendspace.com/file/bg1zhz http://depositfiles.org/files/uv0momxjj
-------------------- "It is dangerous to be right in matters on which the established authorities are wrong." - Voltaire ...just keep folding, just keep folding... :) my config - my caps |
| Posted: Dec 26 2012, 10:19 PM |
Loads fine with fccHandlers flv plugin http://gral.y0.pl/~fcchandler/
| trodas |
Posted: Feb 10 2013, 08:20 PM |
Hoooray! Using fccHandler plugin v2.4 things really work like a charm! Sadly, there: http://forums.virtualdub.org/index.php?act...=ST&f=7&t=19488 is the Moitah plugin still listed. Probably bad idea...
