Reducing Sizes Of Mpegs
tedfat
Posted: Oct 31 2004, 04:51 PM
i am running 1.6
It does run my digital video now ( which 1.5 didnt do) it just opens up in a window a bit to large and i just prefered the 1.5 version.
Am i doing the right thing? Is that how you reduce video size by getting the appropriate codec and then going into vbd and selecting video and compression etc...
tedfat
Posted: Oct 31 2004, 04:58 PM
when i try to capture using the video compression using divx it says cant start video compression: The image format is not acceptable (error code-2)
thebandnerd
Posted: Nov 5 2004, 04:37 PM
when i right clcik it doesnt give me an option of install i am running xp.
i dont have run option either.
tedfat,
Do you have administrator's privileges? Can you install other programs? This could be an issue.
Cyberman
Posted: Nov 5 2004, 05:11 PM
QUOTE (tedfat @ Oct 31 2004, 05:58 PM)
You shouldn´t compress to DivX when capturing anyway...
Are the image dimensions correct? They should be divideable by 16, or at least 4.
Matroska/MKV ?
18 replies since Oct 30 2004, 07:12 PM Track this topic | Email this topic | Print this topic
Pages: (2) 1 [2]
<< Back to Off-Topic
