| Lance |
| Posted: Apr 1 2014, 08:10 PM |
Hello all... I am running the current version of Virtualdub and windows 8.1... I also use quicktime pro to assemble a small clip from still Tiff files, I then save this small movie to AVI to deflicker in Virtualdub..... At the weekend VD was recognizing the AVI files and de flickering them, but today I am getting an error saying "Error reading source frame 0:Can't decompress etc????"
I don't know if it's quicktime that the files appear to be corrupt, but I am not doing anything different that I done with the weekends files??? Any help will be appreciated , many thanks Lance. |
| Abrazo |
| Posted: Apr 1 2014, 08:35 PM |
The most easy way will be to install the FFMpeg inputdriver plugin for VirtualDub (thanks to dloneranger). You can find it here (please try with version V0813): http://sourceforge.net/projects/virtualdub.../?source=navbar
Installation means : unzip FFInputDriver.vdplugin into the plugins32 folder of your VirtualDub installation + unzip the *.dll files into plugins32\ffdlls
After that, start VirtualDub, click File > Open. In the "Open video file"-dialogbox do select the AVI and at "Files of type" do select "FFMPeg supported files". Finally click onto the Open-button. Once the video is open, you can click File > File Information... to see which video- and audio-decoders have been used.
Eventually, you can still install the "video for windows"-compatible video-codec that is needed to open that same AVI without having to use the FFMpeg inputdriver. |
| Lance |
| Posted: Apr 1 2014, 10:47 PM |
Hi... Thanks for the support, but no luck, still won't let me play avi files...I still think it's got something to do with the quicktime pro saving avi, ??? |
| Abrazo |
| Posted: Apr 2 2014, 03:32 PM |
Maybe compressed in MJPEG ?
Try after checking both "Prefer internal video + audio decoders over installed third party codecs" in VirtualDub, via Options > Preferences > AVI.
See what this gives ...
| raffriff42 |
| Posted: Apr 2 2014, 08:26 PM |
Please post a MediaInfo report on your problem video.
Also, please post VirtualDub's error log: * try to open file; * it fails; * hit View, Log; * right-click, Copy; * paste the log in your reply (hint: restart VirtualDub just before doing this or the log may be quite long) |
| Lance |
| Posted: Apr 2 2014, 08:39 PM |
Hi thanks for all the help... Does this help??
[!] Plugins: Failed to load "C:\Users\Reed Family\Desktop\music for time-lapse\plugins32\QuickTime64.vdplugin": Cannot load plugin module "C:\Users\Reed Family\Desktop\music for time-lapse\plugins32\QuickTime64.vdplugin": %1 is not a valid Win32 application.
AVI: Opening file "C:\Users\Reed Family\Desktop\landscape\land_1.AVI"
Also does VD do a plugin for Tiff files for image squence to AVI??? |
| raffriff42 |
| Posted: Apr 2 2014, 09:39 PM |
>plugins32\QuickTime64.vdplugin I think I see the problem... (you need to get the 32 bit plugin)
Also, > C:\Users\Reed Family\Desktop\music for time-lapse\plugins32 "plugins32" needs to be below VirtualDub's home folder (containing VirtualDub.exe) |
| raffriff42 |
| Posted: Apr 3 2014, 02:11 AM |
| QUOTE (Lance @ Apr 2 2014, 08:39 PM) | | Also does VD do a plugin for Tiff files for image sequence to AVI??? | Yes, it's called Avisynth
It's not really a plugin, it's a video filter scripting language and a video frameserver. What that means is you can write something like this in your favorite text editor: | CODE | | ImageSource("filename-%03d.tif", start=0, end=999, fps=30.00) | ... save as <something>.avs, and open the text file in VirtualDub as if it was an .AVI.
The example assumes your TIF files are named "filename-000.tif" through "filename-999.tif." - "%03d" means "three-digit integer in an ascending sequence." - "start=0, end=999" is the first and last frame number to import. See http://avisynth.nl/index.php/ImageSource
Once you have successfully imported your images, you have a wealth of video filters available. Google "avisynth deflicker" ...
If you need help (within reason), just ask!
| Lance |
| Posted: Apr 3 2014, 07:23 PM |
Hey thanks for all your help guys, I really do appreciate it...
I forgot to ask, is this link (Filter)the same as MSU Deflicker, if it's not which in your oppinion is the best one to work with?
http://neuron2.net/deflick/flick.html
Many Thanks. |
| Lance |
| Posted: Apr 4 2014, 09:01 PM |
Hi raffriff...
I have downloaded AViSynth, tested with version script and that works....But The script for the Tiff above is given me a error message of'image open failure, something about can read devildll????? Any advice would be great?? Thanks Lance |
| raffriff42 |
| Posted: Apr 5 2014, 02:13 AM |
Ah yes, my memory is hazy, but I think I had to do this some time ago (from the wiki page) | QUOTE | | 1.7.8 DevIL.dll can be downloaded here. Just put the DevIL.dll in your system folder (it will overwrite the 1.6.6 DevIL.dll which comes with AviSynth). | (BTW DevIL is short for "Developer's Image Library") |
| Lance |
| Posted: Apr 5 2014, 02:31 AM |
LOL I am now getting this error??? I might be doing something wrong...
[E] Error: Avisynth open failure: Script error: expected a , or ) (C:\Users\Reed Family\Desktop\try.avs, line 1, column 23) |
| raffriff42 |
| Posted: Apr 5 2014, 03:23 AM |
Please post your script (you probably forgot to add quotes around the file name & path) |
| Lance |
| Posted: Apr 5 2014, 03:33 AM |
here's my script....
ImageSource("filename= C:\Users\Reed Family\Desktop\xsky\xsun-%03d.tif", start=0, end=250, fps=25.00)
xsky is the folder the images are in and xsun are the tiff images???? |
| raffriff42 |
| Posted: Apr 5 2014, 07:31 AM |
Remove the "filename= ": ImageSource("filename= C:\Users\Reed Family\Desktop\xsky\xsun-%03d.tif", start=0, end=250, fps=25.00)
This should work: ImageSource("C:\Users\Reed Family\Desktop\xsky\xsun-%03d.tif", start=0, end=250, fps=25.00)
Test with 1st image only: ImageSource("C:\Users\Reed Family\Desktop\xsky\xsun-000.tif") |
