Deshaker, how to instal it
timoto
Posted: Mar 14 2014, 01:43 PM
how do I instal deshaker in virtual dub? I cant even download it successfully
Posted: Mar 14 2014, 01:51 PM
All plugins go into a subfolder of virtualdubs
If you have 32bit virtualdub they are put into plugins32
If you have 64bit virtualdub they are put into plugins64
Then when you restart virtualdub they are available on the filters list
Deshaker is available at http://www.guthspot.se/video/deshaker.htm
Downloads fine here
timoto
Posted: Mar 15 2014, 06:22 AM
I've downloaded Deshaker successfully and it is listed in the plugins, but it is not on the filters list in vdub
Posted: Mar 15 2014, 09:57 AM
Checklist
You have 32 bit virtualdub (virtualdub.exe) and inside it's plugins32 folder there is the file deshaker.vdf
or
You have 64 bit virtualdub (veedub.exe) and inside it's plugins64 folder there is the file deshaker_64.vdf
Start virtualdub or virtualdub64
Set 'full processing mode' on the video menu
Select 'filters' on the video menu
Click the 'add' button on the filters dialog box
Deshaker should be on the list
Click on it
Click Ok to add it to the filter list
Click OK on the filters dialog box to return to virtualdub
If that does not work, click on 'log' in virtualdub's 'view' menu
Does the log say anything?
timoto
Posted: Mar 15 2014, 02:37 PM
Mine is 32 bit virtual dub. When I click Add on filters dialogue box, Deshaker is not on the list. There is nothing in the log.
Posted: Mar 15 2014, 04:17 PM
If everything in the checklist was OK then you'll have to take it up with the plugin author
http://www.guthspot.se/video/deshaker.htm#faq
See bottom of the page for his email
Posted: Mar 16 2014, 08:08 AM
Sure to have unzipped the file (from Deshaker30.zip to Deshaker.vdf) ?
When file-extensions in Windows are not shown, it is not always obvious.
To show file extensions:
In Windows Explorer - Tools-menu > Folder options... > View-tab > in the "Advanced settings" list, uncheck "Hide extensions for known filetypes".
timoto
Posted: Mar 16 2014, 02:10 PM
I just can't find out how to do this. In virtualdub-1 is listed: aviproxy, auxsetup.exe, Deshaker.vdf, vdremote.dll and 8 other things. When I click on VirtualDub.exe VirtualDub 1.9.9 appears, but in Video>Filters>Add deshaker is not listed.
Posted: Mar 16 2014, 03:22 PM
It can't be much simpler really
Download the .zip file with it in http://www.guthspot.se/video/files/Deshaker30.zip
Open the virtualdub folder with virtualdub.exe in
Open the Deshaker30.zip file
Extract deshaker.vdf from the Deshaker30.zip file and move it into virtualdub's plugins32 folder
Start virtualdub
For anyone reading this who doesn't know how to open a .zip file
http://www.youtube.com/watch?v=8s2AQs7C3Tw
http://www.youtube.com/watch?v=y6AbcT8dmTs
timoto
Posted: Mar 16 2014, 06:01 PM
I downloaded that. The video says R click on it and you get a menu which says "Explore." When I R click on it I get a menu which says "Open. Show how to open this file. etc." If I click "Open" it says "This file does not have a program associated with it for performing this action. Create an association in the Folder Options control panel." I don't know what that means.
Posted: Mar 16 2014, 06:27 PM
I've extracted it and put it here https://dl.dropboxusercontent.com/u/1702491...16/Deshaker.vdf for you to download
Windows should let you open them all by itself
Seems like you've installed something that opens zip files and have uninstalled it
7zip is a free program that handles zip (and others) http://www.7-zip.org/
timoto
Posted: Mar 16 2014, 06:50 PM
Thanks. My problem now is how to move deshaker.vdf into virtualdub's plugins32 folder. I can't find plugins32 folder. In virtualdub there is a folder called plugins, but if I put deshaker.vdf into it, it still doesn't appear in the list in Video>Filters>Add
Posted: Mar 16 2014, 07:03 PM
Just a plugins folder means you have an older version of virtualdub
(it changed name in the newer versions)
But putting it into the plugins folder is correct for the older versions
Did you start virtualdub after moving the file there?
timoto
Posted: Mar 16 2014, 07:13 PM
I tried putting it into the Plugins folder both before and after opening VirtualDub.exe
timoto
Posted: Mar 16 2014, 07:41 PM
I just downloaded Virtualdub again and now it works!
16 replies since Mar 14 2014, 01:43 PM Track this topic | Email this topic | Print this topic
Pages: (2) [1] 2
<< Back to General Discussion
