Nelp Help With Video
evropej
Posted: Apr 6 2013, 11:21 PM
I processed the videos for you. You should download the files I gave you. Also, you should look at the tutorial video which has virtualdub and all the filters you need. The video you posted in very short and this should fit on a CD let alone DVD. You can use freemake video converter to make a DVD straight from the files. Just drag and drop the files from the link I gave you directly to freemake and choose DVD from the format bar. Click Burn and you are done.
What kind of processor do you have that it takes 15 hours to process?
evropej
Posted: Apr 6 2013, 11:45 PM
www.evropej.com/dvd.iso
I made an iso with the two clips you gave me, it took 1 minute with freemake.
jcool
Posted: Apr 7 2013, 12:30 AM
Ok thanks my processor is AMD-300 APUwith Radeon™ HD Graphics 1.30GHZ
jcool
Posted: Apr 8 2013, 01:42 AM
The actual video is 2hrs long and the video clip looks amazing! Can you make a tutorial for me on how to get videos to look like that I would greatly appreciate it
evropej
Posted: Apr 8 2013, 02:16 AM
Did you watch the first video I posted with a tutorial?
I did the same thing but used a better noise filter, neat video.
jcool
Posted: Apr 8 2013, 10:50 AM
Yes but the video didn't say anything about deinterlacing and upscaling to 720p
jcool
Posted: Apr 8 2013, 08:30 PM
[edited by mod]
You must have the full version of Neatvideo because I have the demo and it only processses 30 minutes and leaves a watermark.
evropej
Posted: Apr 9 2013, 02:48 AM
Like I said, you have to buy neat video, its not free. You can use MSU denoiser, its not as good but does the job. Import these settings into virtualdub ( file, load processing settings)
www.evropej.com/vdub.zip
jcool
Posted: Apr 11 2013, 12:30 AM
Hey I'm using the settings you gave me but how do I save in mp4 format like you did with the two sample videos. I am using the mpeg video that I got the samples from and how did it save in small file sizes like yours did?
evropej
Posted: Apr 11 2013, 01:03 AM
Save it uncompressed if you have the hard drive space. If not, choose xvid as compression. I use freemake video for compressing video. If I have time, I will post a video in a bit.
here is the link for xvid
http://www.xvid.org/Downloads.15.0.html
jcool
Posted: Apr 11 2013, 04:48 PM
Ok post the video when you can.
evropej
Posted: Apr 12 2013, 02:59 AM
here you go
www.evropej.com/compression.mp4
once you compressed to avi xvid format, you can recompress to any other format with this program
its so simple, no video is needed and this is what I use for compression in general, fast and very effective
www.freemake.com/
PS if your vdub crashes when trying to compress the video, go to video, filters, select each filter, click options, select single buffer and do this for each filter.
jcool
Posted: Apr 12 2013, 04:06 PM
Do you use the option same as source when you recompress with freevideo?
evropej
Posted: Apr 14 2013, 12:40 AM
No, I usually recompress to mp4 and downgrade all video 720P fron 1080, custom mode. This is more than enough detail for my 61 inch DLP.
Here is how simple it is to compress videos
www.evropej.com/freemake.mp4
28 replies since Apr 4 2013, 02:05 PM Track this topic | Email this topic | Print this topic
Pages: (2) 1 [2]
<< Back to General Discussion
