| Dstruct |
Posted: Feb 25 2010, 01:43 AM |
Would it be possible to remove the taskbar entry for the "Status" window? I never need this. When hitting the minimize button in it, the VirtualDub's main window should get minimized too.
This would also solve this ugly "default icon" issue: virtualdub-status-window.png
FIXED (1.9.10-test3) |
| Gral |
| Posted: Feb 25 2010, 05:52 AM |
More annoying than 11 identical FireFox icons?
Uncheck "Show status window" under "View" menu. |
| Dstruct |
| Posted: Feb 25 2010, 04:41 PM |
| QUOTE (Gral @ Feb 25 2010, 07:52 AM) | | Uncheck "Show status window" under "View" menu. | But then I don't see the processing status!? |
| squid_80 |
| Posted: Feb 26 2010, 11:26 AM |
I'm curious why the dubbing dialog shows up on the taskbar in the first place, given the .rc file doesn't specify WS_EX_APPWINDOW. |
| Posted: Feb 27 2010, 05:12 AM |
Top-level windows that are not tool windows show up on the taskbar by default. You only need WS_EX_APPWINDOW to force a window onto the taskbar when it wouldn't ordinarily show. |
| Dstruct |
| Posted: Feb 27 2010, 05:43 AM |
So you won't be able to remove that taskbar icon?
If not, can you at least give it the proper VirtualDub icon? Thanks! DONE (1.9.10-test3) |
| Gral |
| Posted: Feb 27 2010, 10:08 PM |
If you uncheck "Show status window" option and minimize VirtualDub (main window) you can watch process status on Windows Taskbar or TaskSwitch window.
| Dstruct |
| Posted: Feb 27 2010, 11:43 PM |
Cool. But wouldn't it be even better if the process status would be displayed with the VirtualDub window in front? Why do I have to minimize it to see the status in this case? |
| levicki |
| Posted: Feb 28 2010, 03:30 PM |
I am curious... why not be able to minimize VirtualDub to system tray (or as Microsoft likes to call it "taskbar notification area") while performing dub operation? It could show progress in a baloon tip (or a custom tip window like eMule) when you hover with your mouse over it or click it. |
| Dstruct |
| Posted: Mar 1 2010, 08:25 PM |
| QUOTE (levicki @ Feb 28 2010, 05:30 PM) | | I am curious... why not be able to minimize VirtualDub to system tray (or as Microsoft likes to call it "taskbar notification area") while performing dub operation? It could show progress in a baloon tip (or a custom tip window like eMule) when you hover with your mouse over it or click it. | I would love a "minimize to tray" option. Tray icon should get hidden automatically when VirtualDub is opened again.
But I wouldn't like a balloon tip/custom tip. The progress could be displayed directly on the trayicon itself (as seen with the download speed in Emule's trayicon or the copy progress in Total Commander's trayicon) ... |
| Dstruct |
| Posted: Mar 18 2010, 02:56 PM |
| QUOTE (Dstruct @ Feb 25 2010, 03:43 AM) | | Would it be possible to remove the taskbar entry for the "Status" window? I never need this.[/IMG] | Same with the Job Control window. Really would like to see it without a taskbar entry ... |
| Oxyandy |
Posted: Mar 18 2010, 11:55 PM |
Ah, I already do this with a third party app... TrayIt! 4.6.5.5 http://www.teamcti.com/trayit/trayit.htm It is a tool I simply can not live without...... I use it with Media Player Classic - Home Cinema when outputting to plasma, the player is placed in systray.. When encoding, in VD I keep main window in systray and status window up..
Don't think main site download link has worked in years ! But can be obtained here ! http://www.brothersoft.com/tray-it-download-73637.html |
| Oxyandy |
| Posted: Mar 19 2010, 01:46 AM |
 VD encoding a movie with status window closed, main window, hidden in systray.. Balloon tip showing progress
Something like this ?? |
| Dstruct |
| Posted: Mar 19 2010, 06:51 AM |
| QUOTE (Oxyandy @ Mar 19 2010, 03:46 AM) |  VD encoding a movie with status window closed, main window, hidden in systray.. Balloon tip showing progress
Something like this ?? | No, tooltips are ugly. |
| levicki |
| Posted: Mar 20 2010, 08:37 PM |
Tooltips are usefull, there should be an option to have them because they can convey more information than the tiny icon alone. |
