| ChristianHJW |
| Posted: Jan 13 2003, 08:37 AM |
| QUOTE | >>ChristianHJW Sorry, I must confess I do not read the mailing lists... |
Dohh !! You're one of the most important developers of this project pulco !! If you dont want to subscribe to it, at least please use news://news.gmane.org , gmane.comp.video.vdubmod.devel and gmane.comp.video.vdubmod.general to browse it from time to time with your newsreader ... it will even allow to reply to it ( gmane.org is a full featured NNTP interface to access MLs with newsreaders ).
| QUOTE | | My opinion about MPEG2 in a different container is like fccHandler's. I can't see the point. |
You guys are all to narrow minded and addicted to MPAA stuff ...
| QUOTE | However, I coded it this way keeping in mind what was my (personal) first preoccupation : speed (more precisely : speed for DVD->DivX conversions). This implies that I'd want any replacement implementation to support 1) YV12 color space 2) a "pre-virtualdub" resizing (that avoids "full processing mode" and all the related color space conversions : MPEG2 frames, at least taken from vobs, often have a wrong aspect ratio) Note that I say this without having tried fccHandler's version... |
You have some valid points here pulco .. isnt it possible to merge some parts from each, like using DVD2AVIs resizing/AR correction, but AC3 handling from fcchandlers code ?
| DeXT |
| Posted: Jan 13 2003, 04:43 PM |
| QUOTE | | Note that I say this without having tried fccHandler's version... |
I put it on my binaries page in case you want to give it a quick test...
http://es.geocities.com/dextstuff/
| QUOTE | | You have some valid points here pulco .. isnt it possible to merge some parts from each, like using DVD2AVIs resizing/AR correction, but AC3 handling from fcchandlers code ? |
That's definitely a good idea. |
| Posted: Jan 13 2003, 05:15 PM |
| QUOTE (pulco-citron @ Jan 13 2003, 04:12 AM) | | However, I coded it this way keeping in mind what was my (personal) first preoccupation : speed (more precisely : speed for DVD->DivX conversions). This implies that I'd want any replacement implementation to support 1) YV12 color space 2) a "pre-virtualdub" resizing (that avoids "full processing mode" and all the related color space conversions : MPEG2 frames, at least taken from vobs, often have a wrong aspect ratio) |
I don't think it's a good idea to have the decoder adjust for odd aspect ratios, for a number of reasons. Such an adjustment will involve resizing the frames. Should we use bilinear or bicubic? Should we expand the width or squash the height? And what if the user wants to use a different frame size for his recompressed movie? Then you wind up doing two resizes per frame, which is grossly inefficient for someone whose "first preoccupation" is speed.
I say let the user decide whether and how any resizing should be done. The role of the decoder is simply that, to decode the data.
IIRC, the decoder will not return frames in YV12 color space, but it should be easy to add support for it.
| pulco-citron |
| Posted: Jan 14 2003, 07:50 AM |
>> fccHandler
Did you try VirtualDubMod ?
If you don't want resize, don't use it. You only end up with two resizes if you request them. if you don't want bicubic, choose bilinear instead, or sharp bicubic, etc...
The mpeg2 extended options dialog was made for this kind of details. |
| RMM |
| Posted: Jan 14 2003, 02:09 PM |
Sorry for my bad English... Is it possible to combine VirtualDub-MPEG2 (open MPEG2 video and MPEG2 audio, do not rename *.mpg in *.vob) with the VirtualDubMod ? It could be great programm! |
| Sarreq Teryx |
| Posted: Jan 14 2003, 05:05 PM |
VirtualdubMod Alpha tester
| QUOTE (DeXT @ Jan 13 2003, 11:43 AM) | | QUOTE | | Note that I say this without having tried fccHandler's version... |
http://es.geocities.com/dextstuff/ |
OINGO!!! I can reencode my (better quality) AIW output now!!!!!
| Posted: Jan 14 2003, 07:00 PM |
| QUOTE (pulco-citron @ Jan 14 2003, 03:50 AM) | | Did you try VirtualDubMod ? | Why would I use VirtualDubMod when I've had my own version with MPEG-2 support for years?
But yes, I did try it once. It was clumsy and confusing (why do I have to rename everything ".vob"?), kept resizing itself on my desktop (can't I turn this off?), and then one time it crashed so bad I had to hit the power switch. Thanks, but no thanks.
I might need VirtualDubMod if I get into ogg someday, but ATM I have no use for it.
| Sarreq Teryx |
| Posted: Jan 15 2003, 06:55 AM |
| QUOTE (pulco-citron @ Jan 14 2003, 02:50 AM) | Did you try VirtualDubMod ?
But does it do MPEG2 audio or AC3?
| konis |
| Posted: Jan 18 2003, 08:47 AM |
| QUOTE (fccHandler @ Jan 10 2003, 01:03 AM) | First, let me say that I am not trying to compete with jcsston or the VirtualDubMod developers. I've had this code for years and I've finally made a decision to release it into the wild, with the hope that perhaps those developers might benefit from it.
It's an internal upgrade of VirtualDub's MPEG decoder, and only the source code is being made available. DO NOT ask me for a compiled version. (Do it yourself.)
Anyway, you are free to use the code as you wish, modify it all you want, and make it your own. In turn, I absolve myself of any responsibility, and if it doesn't work for you, too bad.
Instructions: Replace your existing VirtualDub 1.4.13 source files with these:
http://home.attbi.com/~blade66/Mpeg.cpp http://home.attbi.com/~blade66/mpeg_decode.cpp
Rebuild VirtualDub, and you'll be able to open MPEG-2 content directly.
AC3 support is disabled in this version. If there is any interest, I can tell you what you need to do to enable it. |
Thanks for that job, its great like Avery, many thanks...
but I need the AC3 support enabled, how can get and install? |
| DeXT |
| Posted: Jan 18 2003, 10:38 AM |
| QUOTE | but I need the AC3 support enabled, how can get and install? |
You cannot "install" this. This needs to be compiled. The binaries on my page already have AC3 support enabled, for your testing pleasure. Just remember to copy the files to a valid VirtualDub instalation, because of the missing dlls.
DeXT |
| ChristianHJW |
| Posted: Jan 19 2003, 11:45 PM |
I added a new link for the binaries on my fast webspace ... it has no download limit ( they never sent me a new contract .. lol ), you shouldnt have any probs
Binaries
Sources
| KornX |
Posted: Jan 20 2003, 08:07 PM |
I have noticed, that the first frames have blocks in them with the decoder of you, the vd mod decoder doesn't get them!!! Somebody noticed the same??? KornX
-------------------- There are only 10 types of people; Those who do and those who don't understand binary. |
| S_O |
| Posted: Jan 21 2003, 03:55 PM |
Yes, I found that bug, too. When you seek fast to the video forward, and then backward you get broken frames. Another possible problem: also mpeg-2 audio is not vaild in mpeg-1-streams, it is in mpeg2-streams, and nekoamp most likely wonīt decode it (I couldnīt test it, because i didnīt found any good multiplexer for mpeg-2, ffmpeg cannot mux mpeg-2 at all, bbmpeg and tmpgenc doesnīt work with mpeg-2 audio). Maybe in the mpeg2-version nekoamp should be replaced. Also didnīt anyone change the source for the new a52lib yet? Anyway great work fccHandler, thank you very much!
Edit: I forgot one bug: DTS-streams are reported as Dolby AC3. If you load an DTS-stream as audio, you get simply silence as audio and the info-box the info is just crap (162 kbps ac3?)
| dan2304k |
| Posted: Jan 26 2003, 03:49 AM |
This is great work guys, but I would like to be able to to a *real* direct stream copy on ac3 audio. I'm working with HDTV mpeg2 source, eventually making DVDs. Since I'm going to DVD, I don't want a two channel downmix, I really want to be able to get the original ac3 audio.
Of course, I could do this by demuxing the original mpeg, but I'm using Virtualdub to edit out commercials, and it would be incredibly nice to be able to cut both audio and video in one shot. -- My current work-around takes hours and is a real PITA. I only wish I could save as AVI with ac3, or use the "save as WAV" to extract a cut ac3 stream
I've taken a long look at source but I simply can't see what's going on well enough to add the necessary code myself. If anyone would be willing to make this modification, I would be sooo thankful. -- Perhaps it could be useful for others as well? |
| Posted: Jan 26 2003, 04:23 AM |
| QUOTE (dan2304k @ Jan 25 2003, 11:49 PM) | | ... I would like to be able to to a *real* direct stream copy on ac3 audio ... I don't want a two channel downmix, I really want to be able to get the original ac3 audio. |
I don't know if VirtualDub can work with audio with more than 2 channels, and it seems like you would have to modify the ac3dec source also. But I agree it would be a nice feature.
I'll add it to my todo list, which is getting quite long.
