| m12462 |
Posted: Jul 31 2014, 07:10 AM |
I downloaded the "QuickTime / MPEG-4 (MOV / MP4)" Plugin from the "Pinned: Links to Virtualdub Filters and Input Plugins" section at the top of the page...
The installation process seemed simple enough but when I tried to open my first MP4 in Vdub, I got the following error message:
I loaded the video in question into GSpot for the pertinent info (below). Did I download the wrong plugin for the video I wanted to edit or, if not, is my mistake obvious.
Any assistance would be appreciated. Being able to open MP4's would be extremely help to me.
Thanks!!
| Posted: Jul 31 2014, 11:32 AM |
That and requires Quicktime to be installed The MP4 plugin (fcchandlers) is better but requires that you have the right VFW and ACM codecs installed, usually x264vfw and the aac codec in my sig
The FFMPeg plugin can open almost everything without codecs etc, but you can't do 'direct mode' copying The DirectShow plugin uses any installed DirectShow codecs, but you can't do 'direct mode' copying
| m12462 |
| Posted: Aug 1 2014, 05:02 AM |
Thanks dloneranger! I downloaded the FFMpeg Input Plugin but when I unzipped it, I simply had an "ffmpeg" folder with three sub folders in it...
Can you give a brief explanation on how to actually install this plugin so it will open my mpeg files in Vdub?
Thanks again! |
| Posted: Aug 1 2014, 05:16 AM |
That's the source code in case you wanted to compile it yourself
The plugin's available as a .zip with the 32 and 64 bit versions inside http://sourceforge.net/projects/virtualdub...16.zip/download If you have 32bit virtualdub, extract the plugins32 folder to virtualdubs location If you have 64bit virtualdub, extract the plugins64 folder to virtualdubs location
| m12462 |
| Posted: Aug 1 2014, 06:08 AM |
Great...thank you! |
