(german) Capture Faq, it needs to be translated
SillKotscha
  Posted: Jul 15 2002, 10:12 PM
smart Moderator
hi guys,
I've wrote (not only me) a good Capture FAQ but in german language. In some terms it goes into technical statements... as it should. I believe this FAQ is a good starting point for recording analog input but it needs to be translated!! I could describe it but not really translate it. That's my problem. What I need is your help to translate this FAQ from german2english.
Participate to make this FAQ open to all interested and not only to german readers.
your feedback is welcome!!
regards Sill
ChristianHJW
Posted: Jul 15 2002, 10:16 PM
Hi Sill,
just read your last email about the FAQ, great !!
I dont know if i will have the time to help with translation, but i will definitely try .... BTW : where is it ? Did you attach it here ?
SillKotscha
Posted: Jul 15 2002, 10:20 PM
smart Moderator
no, the link wasn't mentioned before 'cause I don't want to steel german readers biggrin.gif
but I see it is demanded...
have a closer look to the german Capture FAQ
cheers Sill
smokeslikeapoet
Posted: Aug 19 2002, 10:27 PM
I started a Virtual Dub capture guide for www.everwicked.com then I got swamped with work and couldn't continue. I'd like to pick up where I left off if anyone else would care to help.
SillKotscha
Posted: Aug 21 2002, 09:25 AM
smart Moderator
hi smokeslikeapoet,
I can help you, no problem... I don't know your native language but if it's german maybe we can combine our guides and then translate them. Even though my guide isn't that old I found out some "better" ways to capture respectively some lines should be updated.
cheers Sill
P.S.: if german isn't your native language then it is even better because you can correct my crappy english biggrin.gif
ChristianHJW
Posted: Aug 21 2002, 10:08 AM
sill,
smokeslikeapoet is a real US boy, so its definitely a good option if he makes the Guide, maybe with your help ??
SillKotscha
Posted: Aug 21 2002, 10:15 AM
smart Moderator
QUOTE (ChristianHJW @ Aug 21 2002, 12:08 PM)
that was my intention...
6 replies since Jul 15 2002, 10:12 PM Track this topic | Email this topic | Print this topic
<< Back to Capture
