Virtualdub And Yuy2 And Other Yu Formats, ahhhhh!
exorcism
Posted: Aug 23 2002, 10:48 PM
okay, no matter what I do it seems virtualdub always opens YUY2 files and converts them to RGB, is there anyway to keep it from doing this? My main reason is encoding mpeg2 streams (such as dvds) using avisynth/vfapi and when it converts it to RGB format, it takes a very very long time. Any Help? Thanks!
GreatLord
Posted: Aug 24 2002, 12:27 AM
if u use a avisynth script with mpeg2dec.dll. and sett vsub to fastrecompressing you will get yuv2.
exorcism
Posted: Aug 24 2002, 12:29 AM
vsub?
SillKotscha
Posted: Aug 24 2002, 03:03 AM
smart Moderator
translation:
if you use an avisynth_script...
LoadPlugin("d:\mpeg2dec.dll")
mpeg2source("d:\filename.d2v")
and set virtualdub to 'fast recompress' than this makes sure that the Color Space remains in YUV which also speeds up encoding by about 10%-20%.
as you mentioned that your aim is encoding mpeg2 streams, here is just another option...
load your mpeg2 file in DVD2AVI (hit 'show all formats' to find your mpeg2 stream) and save it as a *.d2v file. This file can easily be opened by GordianKnot. Now you'll have a variety of choices to work on your stream. Save the project (not save and encode!) as a *.avs file... and here is the little trick for you. GordianKnot can create a SVCD compliant avisynth script for you. This script can be either opend by virtualdub to encode your stream (you'll recieve an avi file but then there is no need for you to edit your script SVCD compliant) or you can feed this sript to TMPEG which will give you a (S)VCD after encoding with the free TMPEG encoder. For further details (guides) have a look over to doom9.org or just ask if something won't work as expected.
cheers Sill
GreatLord
Posted: Aug 25 2002, 09:53 PM
QUOTE (SillKotscha @ Aug 23 2002, 07:03 PM)
Yes I was lite fast, I do get this question very oftten in a group call flaskmpeg or directly per e-mail.
sorry I dd not get into detail
4 replies since Aug 23 2002, 10:48 PM Track this topic | Email this topic | Print this topic
