Virtualdub Merge Several Parts Of Mov ?
kkdd
  Posted: Oct 28 2014, 05:38 AM
hello
i have VirtualDUB 1.10.4 and QuickTime64.vdplugin
can i merge several parts of MOV and not re-render the movie?
use the "Direct stream copy" ?
Or, any application will do. Something similiar to "Direct stream copy" in the freeware VirtualDUB, but for MOV-files instead of AVI-files.
thanks
Placio74
Posted: Nov 2 2014, 01:38 AM
VideoAudio
You can use Direct stream copy after import video through fccHandler's QuickTime plugin, but can't append other.
Can merge .mov files using FFmpeg.
Or (if A/V is compatible with output container) can merge using MP4Box or MKVtoolnix (mkvmerge) or Avidemux.
1 replies since Oct 28 2014, 05:38 AM Track this topic | Email this topic | Print this topic
