| rmanal |
| Posted: Apr 18 2014, 06:33 AM |
I would like more info on how and which decoder/encoder is using VD. When I open a file, does it ise an VFW and ACM codec or just directshow filter? Same when displaying the image (preview)?
When it recompresses, it only uses VFW and ACM codecs if I have well understood.
Am i right?
Thank you Rmanal |
| Posted: Apr 18 2014, 02:52 PM |
Decoding It uses vfw and acm codecs in normal operation (without a plugin) Plugins may use vfw/acm, directshow codecs or their own (FFMPeg) (It's up to the plugin how the file is decoded)
Virtualdub normally uses the OS's own system for determining which codec to use for a fourcc code Plugins may decide a different way
Encoding Normal use is to use installed vwf/acm codecs Using the external encoder options you may use other methods of encoding (.exe's etc) and muxing to different containers (.mkv etc)
| rmanal |
| Posted: Apr 22 2014, 09:07 AM |
Clear: thank you |
