| Sarreq Teryx |
| Posted: Jul 17 2002, 12:00 AM |
VirtualdubMod Alpha tester
Has anyone been able to get data partitioning to work at all? every time I try, the first chunk plays fine, then from the 2nd and on the video is totally screwed, encoding either from virtualdub or tmpeg, haven't tried others yet though
| SillKotscha |
| Posted: Jul 17 2002, 12:38 AM |
smart Moderator
Hi Sarreq Teryx,
welcome to this board. In fact your problem isn't really vd related. It is a known issue of DivX Pro™ Software 5.x
| QUOTE | | Data parititioning is not supported with B-VOPs (i.e., B-frames) as specified in the MPEG-4 standard (ISO/IEC 14496/2:2001). This means you should not use data partitioning with B-frames and vice versa. Using the two together may cause artifacts in the encoded content. Both features work fine separately. |
regards Sill
| BaronVlad |
| Posted: Jul 17 2002, 01:01 AM |
Terrorhörnchen
There is no prob when using datapartitioning in VDub when you do it like this:
1. Use datapartitioning while encoding with divx
After that the file wont work in WMP but in the Divx alpha Player
2. Open the encoded file in VDub and compress audio to mp3
File works with wmp also
This could help you ? It works for me...
@ Sill: They fixed that bug with the new version (they said )
| SillKotscha |
| Posted: Jul 17 2002, 01:32 AM |
smart Moderator
congrats @ BaronVlad
you solved the problem by using a detour (why not!) but it's not true that they fixed that bug with the current version... as you can read it here ...
btw, @Sarreq Teryx
http://forums.divx.com/viewtopic.php?topic...=38182&forum=16 ??
regards Sill
| BaronVlad |
| Posted: Jul 17 2002, 01:45 AM |
Terrorhörnchen
| QUOTE (Sarreq Teryx @ Jul 16 2002, 06:00 PM) | Has anyone been able to get data partitioning to work at all ?
Sorry, think i misunderstood your question, but in my testruns (from a capture) it looks pretty fine, no artefacts, as I can judge it with this sample...
| Sarreq Teryx |
| Posted: Jul 17 2002, 04:28 AM |
| QUOTE (BaronVlad @ Jul 16 2002, 07:01 PM) | There is no prob when using datapartitioning in VDub when you do it like this:
@ Sill: They fixed that bug with the new version (they said ) |
possibly, I'll try it out, but wouldn't that break the partitioning, or does it only apply to the video portion of the file (video chunked, audio not) in the first place?
and also, I'm unable to get it to work with bframes off also
| BaronVlad |
| Posted: Jul 17 2002, 10:09 AM |
Terrorhörnchen
| QUOTE (Sarreq Teryx @ Jul 16 2002, 10:28 PM) | possibly, I'll try it out, but wouldn't that break the partitioning, or does it only apply to the video portion of the file (video chunked, audio not) in the first place?
and also, I'm unable to get it to work with bframes off also |
Hm..Strange, with b-frames off I had no probs, then it also runs with wmp !!??
Thought it would only apply to the video as you set audio directstreamcopy when encoding, afterwards you set videodirectstreamcopy when encoding audio, Think the packages should be there after this (?)
And with mp3 there should not be a problem, as you can use it for streaming, cant you ?
