| Nemolo |
Posted: Mar 15 2013, 12:37 PM |
Hi community, i'm having some problem with a script i have to do. i want to use virtualdub to cut a video file (.mpg) and i have to call it from an other program, so it must be used from command line like this vdub.exe /i script.jobs <input.mpg> <output> <startframe> <endframe>
and this is the script i have done(partially stolen):
| CODE | // $signature 0 1 // $numjobs 1 //
// $job "Job 1" // $input "c:\sourcedir\input.avi" // $output "c:\outputdir\output__1_.avi" // $state 0 // $id 5141efec95f611363275757 // $start_time 00000000 00000000 // $end_time 00000000 00000000 // VirtualDub.video.SetSmartRendering(0); What is this? // VirtualDub.audio.EnableFilterGraph(0); what is this?
// USAGE // From command line: // Vdub.exe /i script.jobs <imput path.mpg> <output path> <startframe> <endframe> // still testing
// $script
declare input; declare output; declare startframe; declare endframe; declare intstartframe; declare intendframe; declare frames;
input = VirtualDub.params[0]; output = VirtualDub.params[1]; startframe = VirtualDub.params[2]; endframe = VirtualDub.params[3];
intstartframe = Sylia.Atoi(startframe); intendframe = Sylia.Atoi(endframe);
frames = intendframe - intstartframe;
VirtualDub.Log("Input path:"); VirtualDub.Log(input); VirtualDub.Log("Output path:"); VirtualDub.Log(output); VirtualDub.Log("StartFrame:"); VirtualDub.Log(startframe); VirtualDub.Log("End Frame:"); VirtualDub.Log(endframe);
startframe = Sylia.ToString(intstartframe); endframe = Sylia.ToString(intendframe);
VirtualDub.Log("Elaborated Frames:"); VirtualDub.Log(startframe); VirtualDub.Log(endframe);
VirtualDub.Open(input); VirtualDub.audio.SetSource(1); VirtualDub.audio.SetMode(0); VirtualDub.audio.SetInterleave(1,500,1,0,0); VirtualDub.audio.SetClipMode(1,1); VirtualDub.audio.SetConversion(0,0,0,0,0); VirtualDub.audio.SetVolume(); VirtualDub.audio.SetCompression(); VirtualDub.video.SetInputFormat(0); VirtualDub.video.SetOutputFormat(0); VirtualDub.video.SetMode(3);
VirtualDub.video.SetPreserveEmptyFrames(0); VirtualDub.video.SetFrameRate2(0,0,1); // without this lane the video is good but the progression bar fails VirtualDub.video.SetIVTC(0, 0, 0, 0); VirtualDub.video.SetCompression(); VirtualDub.video.filters.Clear(); VirtualDub.audio.filters.Clear(); VirtualDub.subset.Clear(); VirtualDub.subset.AddRange(intstartframe,intendframe); VirtualDub.video.SetRangeFrames(intstartframe,intendframe); VirtualDub.project.ClearTextInfo(); VirtualDub.project.AddTextInfo("ISFT", "VirtualDub AutoCut"); // -- $reloadstop -- VirtualDub.SaveSegmentedAVI(output+".mpg", 2000, 0); VirtualDub.SaveAVI(output+"AVI.mpg"); VirtualDub.SaveCompatibleAVI(output+"_Compatible.mpg"); VirtualDub.audio.SetSource(1); VirtualDub.Close();
// $endjob // //--------------------------------------------------
// $done
now: i have some issues with the methods : VirtualDub.video.SetFrameRate2(0,0,1); // VirtualDub.video.SetSmartRendering(0); // VirtualDub.audio.EnableFilterGraph(0);
since i dont' know exactly what they do.
also, i need an exact copy of the section i'm cutting: same frames, same audio, same codec. instead i get a much bigger file.
23:51min input file (240177KB) -> 22sec output file(221221KB)
how can i encode the file with the original codec?
i strongly hope someone can answere me.
(sorry for the grammar hell, i can't speak english very well)
| -vdub- |
| Posted: Mar 15 2013, 08:16 PM |
One way is to load video into virtualdub apply filters and edits then either use File - Queue Batch Operation - Save As Avi or File - Save Processing Settings. After saving them with or without closing virtualdub these script files will be in virtualdub folder or location you saved them to. With extensions of .jobs for batch and .vdscript or .vcf for process settings. From those you can find what you need to know. While not exactly the same for all will give you more idea for those that are what is needed and where, trial and error to learn. Unknown if there is an A-Z for every detail and much more besides for the script you have posted.
These you will se change in the .jobs, vdscript, .vcf files when selected from within virtualdub VirtualDub.video.SetFrameRate2(0,0,1); = Video - Framerate (options) // VirtualDub.video.SetSmartRendering(0); = Menu Video and help file for more details for these // VirtualDub.audio.EnableFilterGraph(0); = Audio Full Compression - Use Advanced Filters <then> Filters
Many other questions no doubt will be in the Virtualdub Help F1 or Help - Contents for Virtualdub Help. |
| Nemolo |
| Posted: Mar 16 2013, 09:44 AM |
that really helped, thank you, this job is easier now. i can select a codec without scripting it. but sorry if i bother you, how can i detect the codec of my original video? |
| Abrazo |
| Posted: Mar 16 2013, 08:49 PM |
Once the videofile is open in VirtualDub, you can verify which video- and audio- decoders have been used for it, via File > File Information...
The "decoding"-codec being used by VirtualDub is not necessarely the same one as the "encoding"-codec that has been used while the file has been created, but it gives you an indication if it has been encoded with DivX, Xvid, H264, ...
So it can be that an AVI has been encoded with the native DivX codec and that VirtualDub will open it via ffdshow's Divx/DX50-capable decoder.
If you are more interested in these things: > you can read this thread - starting from 3 aug. 2012 > http://forums.virtualdub.org/index.php?act...=ST&f=4&t=21095
AVI FourCC code changer: > http://www.inmatrix.com/download/avic100.zip FourCC Description Code: shows you the encoder that has been used FourCC Used Codec: the encoding-format |
| -vdub- |
| Posted: Mar 17 2013, 03:42 AM |
MediaInfo to show the codec used encoded the video http://mediainfo.sourceforge.net/ |
| Nemolo |
| Posted: Mar 18 2013, 11:44 AM |
Thanks, with this i can solve all the problems i got. |
