| Spider-Mann |
| Posted: Aug 22 2012, 06:59 PM |
Hello, i want to do the following:
Video encoding with the internal x264vfw-Codec.
Audio encoding with the internal ac3acm-Codec.
Multiplexing with an external mkvmerge.
Is this possible, and when yes, how can i do this? |
| Posted: Aug 22 2012, 07:35 PM |
If you want to do it that way, the easiest thing to do is save as an avi, and then turn the avi into an mkv
A batch file makes it all nice and easy change the set mkvmerge=....... to point to the right place and save this as a .bat file, then you can just drag avi's onto the .bat file
| CODE | @echo off rem set path to mkvmerge.exe here set mkvmerge="%cd%\mkvmerge.exe"
:loop set DataFullFilePath=%~1 set DataFileName=%~n1 set Outputfile=%~dpn1.mkv
if "%DataFullFilePath%."=="." goto nomore echo MKV'ing %DataFileName%
rem ---------------- rem this next bit is one long line, but it's wrapped in the code block rem ----------------
%mkvmerge% -q -o "%Outputfile%" "--language" "0:eng" "--default-track" "0:yes" "--forced-track" "0:no" "--language" "1:eng" "--default-track" "1:yes" "--forced-track" "1:no" "-a" "1" "-d" "0" "-S" "-T" "--no-global-tags" "--no-chapters" "(" "%DataFullFilePath%" ")" "--track-order" "0:0,0:1" rem ---------------- rem end of the long line rem ----------------
if %ERRORLEVEL% gtr 0 goto mergeerror goto loopdone
:mergeerror echo Error %errorlevel% mkv'ing file echo "%DataFullFilePath%" echo to echo "%Outputfile%" pause
:loopdone @echo. @shift @goto loop
:nomore @echo. @echo ------------------------------------ @echo All Done @pause @exit
If you'd rather do it with external encoders you can look here http://forums.virtualdub.org/index.php?act...=ST&f=3&t=18840
| Spider-Mann |
| Posted: Aug 22 2012, 08:10 PM |
Thank you, that's exactly what I'm doing at the moment, but without script. |
