Mmx State Left..., Problem with video stream error scan
farfrumet
  Posted: Sep 4 2002, 09:06 PM
Does anyone know of a workaround related to the fatal error message something along the line of "left MMX state" when scanning the video stream for errors... Is there another tool that someone knows of that I can use to preprocess the .avi before using Virtual Dub to handle masking over errors?
farfrumet
Posted: Sep 4 2002, 09:51 PM
Okay...just found a tool that looks like it will help called DivFix. I found it at:
http://divfix.maxeline.com
If there is a better tool, lemme know.
Tut_Ank
Posted: Sep 6 2002, 05:44 AM
QUOTE (farfrumet @ Sep 4 2002, 03:06 PM)
I use this: http://www.geocities.com/divx_repair/files...-mp3-freeze.zip
this checks the video for errors and stores then in c:\badframes.log file (can't be changed) then you can select those frames and mask them manually.
2 replies since Sep 4 2002, 09:06 PM Track this topic | Email this topic | Print this topic
