Video File Massive And Distorted... Why?!
dragonsfire1981
Posted: Feb 10 2015, 12:20 PM
Hi there,
First time user of VirtualDub. I'm applying noise reduction filters to an avi file- but after I saved it upon applying effects and it rendered, it was disproportionately large- 9.2 GB when the original was 114 MB. And upon playback the clip was stuttering. What the hell is going on, have I got the settings wrong?!
Gral
Posted: Feb 10 2015, 01:03 PM
http://forums.virtualdub.org/index.php?act...t=ST&f=4&t=5503
dragonsfire1981
Posted: Feb 10 2015, 01:21 PM
Okay,
I figured out one part of the problem- I read I need to install a compression codec. I've just installed DIVX10. it seems to ahve solved one problem.
dragonsfire1981
Posted: Feb 10 2015, 01:22 PM
QUOTE (dragonsfire1981 @ Feb 10 2015, 01:21 PM)
Okay,
Thanks I found the solution just before you posted!
3 replies since Feb 10 2015, 12:20 PM Track this topic | Email this topic | Print this topic
