I Need Help With My Audio
Saul Chavez
Posted: Feb 8 2015, 09:46 PM
Hey guys I made this account cause I had problems since yesterday with my youtube video intro like no sound comes out of it like this is what it says "[!] AVI: Variable bitrate (VBR) audio detected. VBR audio in AVI is
non-standard and you may encounter sync errors up to 36ms when attempting
to extract WAV files or playing in some players. If this is a problem, use
Full Processing mode is recommended to decompress or recompress the audio.
(This warning can be disabled in Options, Preferences, AVI. bitrate: 195.5
± 25.1 kbps)"
that is what pops up with the AVI version of my intro and no sound comes out of it and in the original version when I push play it says "No audio decompressor could be found to decompress the source audio format" (source format tag: 00ff) and no audio come out can someone please help me with this problem!
ALbino
Posted: Feb 9 2015, 12:05 AM
Sounds like an AAC audio problem. Try using the FFMpeg Input Plugin:
http://sourceforge.net/projects/virtualdub...peginputplugin/
If that fails, you could just convert the audio (AAC or otherwise) to something else.
Saul Chavez
Posted: Feb 9 2015, 03:50 AM
Okay I'll try that out. If that dont work can you tell me how to convert it?
Posted: Feb 9 2015, 05:56 AM
If you need an acm codec for other plugins (or .avi files) the link is here
https://sourceforge.net/projects/fcchandler/files/
It's easiest to use the SetupAACacm_X86_X64.zip installer
3 replies since Feb 8 2015, 09:46 PM Track this topic | Email this topic | Print this topic
