Only 1 Audio Stream Showing Up
ajohn05
Posted: Jan 24 2015, 03:25 AM
Hi, I'm trying to fix some of my Bandicam recordings using VirtualDub. In my recordings, I can only hear what is on my computer and not my voice as well. I have since fixed the issue and Bandicam is working fine. However, I would rather not have to rerecord my other vidoes. According to this video, I can fix the old videos in a few steps (https://www.youtube.com/watch?v=3cOaf2v7lo4). However, I'm running into an issue when I get to the source audio. Only 1 stream is present, regardless of the video I select (one where I can only hear my computer or one where I can hear both my voice and my computer).
Does anyone know why this is and how I can fix it? I've searched everywhere, but there doesn't appear to be a solution for this anywhere online (at least not one that I could find). Thanks.
Posted: Jan 24 2015, 10:37 AM
Virtualdub loads videos with multiple audio tracks, but only works with one of them
You select which stream you want from the audio menu->source audio
The trouble is that when saving, you'll only get that track
I'd try AviDemux
http://fixounet.free.fr/avidemux/
You should be able to load the file and directly convert the tracks to mp3 without all the messing about in the youtube video
Set video to copy and audio to mp3(lame) then save
1 replies since Jan 24 2015, 03:25 AM Track this topic | Email this topic | Print this topic
