| pitbull |
| Posted: Nov 25 2014, 09:21 AM |
Hello, lets say i want my video to be 30fps what should my
| CODE | | VirtualDub.video.SetFrameRate(#,#) |
be like? |
| Posted: Nov 25 2014, 12:06 PM |
Depends on which kind of frame rate you want The simple set frame rate version is this in a saved script VirtualDub.video.SetFrameRate2(30,1,1);
The easiest way to see what you need is to set it all how you like in virtualdub and then 'save processing settings' Read that file with a text editor and you'll find what you need
| pitbull |
| Posted: Nov 26 2014, 02:23 AM |
wow! that worked! i did not know that there was SetFrameRate2 and how it worked... The text documentation of virtualdub is insufficient and I hope that somebody will update that in the future. as a gesture of gratitude to the community, I will share part of my code for anybody's use...if there is indeed some educational value in this...
PYTHON CODE
| CODE | import subprocess,os
#variables src = r"this is your image sequence file dir and name" dst = r"this is your video file dir and name" vcf = r"the path and file to the temporary vcf file"
#check for existing files if os.path.isfile(vcf): os.remove(vcf) if os.path.isfile(dst): os.remove(dst)
#make temporary vcf file and and run that file with open(vcf,"w+") as f: f.write('VirtualDub.Open(U"%s");\nVirtualDub.video.SetFrameRate2(30,1,1);\nVirtualDub.SaveAVI(U"%s");' % (src,dst)) subprocess.call("%s /s %s /x" % (vdub,vcf), shell = False)
#clean up vcf file if os.path.isfile(vcf): os.remove(vcf)
