Audio Codec Needed For Stupid Problem, playing troubles
Melkor
Posted: Nov 14 2002, 10:54 AM
these apps won't play the audio portion on not at all on my computer
when they have wav-mp3 audio
AVISynth files
VirtualDub, et al.
Media Player (XP) - Mplay32.exe
But will play in any other player. like
Windows Media Player - old and new
Old ActiveMovie OCX viewer from windows 95
Media Player Classic
I am convinced it is a codec problem
it drives me nuts
any ideas on how to solve this problem would be appreciated.
Morsa
Posted: Nov 14 2002, 09:16 PM
install radium or Lame ACM codecs.
Melkor
Posted: Nov 18 2002, 01:37 PM
Radium worked, sorry for not posting in the newbie forum. i haden't seen it yet.
Melkor
Posted: Nov 18 2002, 01:57 PM
still doesn't work
i don't need to encode the audio.
i need to decode it.
Morsa
Posted: Nov 18 2002, 08:37 PM
Try using ffdshow.It is a directshow filter which works really good.
Also if ffdshow plays your audio portion, you can use avisynth with directshowsource and get the uncompressed audio stream.
For information about using avisynth go to doom9 forums.
Neo Neko
Posted: Nov 19 2002, 05:16 PM
VirtualdubMod Alpha tester
FFDSHOW is video only BTW. If win 95 apps can decode it could likely be WMAv2.
5 replies since Nov 14 2002, 10:54 AM Track this topic | Email this topic | Print this topic
