| AAL1947 |
| Posted: Oct 1 2002, 05:19 PM |
HAVE VARIOUS DOWNLOADED VIDEOS THAT ARE INCODED IN 'MPEG4' THAT I WOULD LIKE TO CONVERT TO 'DIVX' . HOW EVER VITUAL DUB GIVES ME THIS ERROR: SOURCE IMAGE FORMAT IS NOT ACCEPTABLE (ERROR CODE-2).
HOW DSO I GET AROUND THIS? TRYING TO GET ALL OF MY VIDEO FILES RE-ENCODED TO DIVX. HAVE SIMILAR PROBLEM WITH 'DIV3' FILES.
HELP PLEASE AND PLEASE MAKE IT SIMPLE. |
| ChristianHJW |
| Posted: Oct 2 2002, 01:32 PM |
Here is the 'Simple' answer, as requested :
1- You forgot to use the 'search' function here, which is impolite
2- You are using BOLT LETTERS TO MAKE YOUR QUESTION LOOK VERY IMPORTANT, being even more impolite
3- You have a bunch of files encoded in either Microsoft ( M$ ) MPEG4V3 ( FourCC : mp43 ) or DivX3.11 codec ( FourCC : div3 and div4 ), both being illegally used in AVIs, latter being a 'hack' of first.
4- It would have been easy to find out ( again by using the 'search' button ) that both codecs mentioned above have not much to do with MPEG4ISO standard codecs ( like DivX 5 ), but are Microsoft MPEG4 standard compliant and its impossible ( at least for the time being, i heard there are ideas how it could be done ) to convert them into MPEG4ISO streams.
5- I dont have a real clue what you mean with 'converting to DivX5' , you could have described a bit more detailled what you are trying to achieve and what your problem is. Cant you play the files ? Do you have a MPEG4 hardware decoder card and it refuses to play your movies ?
Please be a bit more polite to us here with future postings. Thanks ....
| Posted: Oct 3 2002, 04:30 AM |
ATTN: AAL1947
Both of your posts have used "BOLT" lettering, as ChristianHJW pointed out. I think your Caps Lock key may be stuck. I recommend you separate the plastic layers of your keyboard and wash them with a mild soap and water solution.
| AAL1947 |
| Posted: Oct 4 2002, 02:23 AM |
Sorry About the CAPS before but, my eye sight gets blurry sometimes and caps are easier to read then.
Am trying to re-encode everythiung that has been downloaded to Diovx5 so that eveything is Leagl. |
| Posted: Oct 4 2002, 06:39 AM |
| QUOTE (AAL1947 @ Oct 1 2002, 01:19 PM) | VITUAL DUB GIVES ME THIS ERROR: SOURCE IMAGE FORMAT IS NOT ACCEPTABLE (ERROR CODE-2).
To re-encode to "Diovx5" and make everything "Leagl", the video height must be a multiple of 2, and the width must be a multiple of 4. If your illegal videos do not conform to these restrictions, you'll need to rescale them.
| ChristianHJW |
| Posted: Oct 5 2002, 08:12 PM |
Can you tell us exactly what virtualdub tells you about the FOURCC of the videos used ? It is essential to give you the right recommendations.
Please ignore my answer about using CAPS, your email clarified why you have to use them.
| Posted: Oct 6 2002, 06:33 AM |
Sorry to make fun of your CAPS. My eyesight is not so good either.
The only time I have ever seen the error you described is when I've tried to recompress a video in which the height or width was odd, or not a multiple of 2 (or 4). But regarding my previous post, it occurred to me that it might be better in this case to crop a few pixels than to rescale.
| AAL1947 |
| Posted: Oct 8 2002, 06:50 AM |
Okay here is what I am trying to do. Have 6 seasons of BTVS downloaded which are encoded anywhich way from Div3 -> MPEG also with various audio encodes and lengths.
Want to re-encode/re-compress using Virtualdub and Divx5.02. Settings at present are: Filters: Null and then resize tio 360 x 240. Frame Rate: whatever download was. Video Compression Divx 5.02 - 443kbits on general tab which is what AdvBitCal gives for a 43min video using 200MB. Audio Conversion is 44100Hz, intergal conversion, HQ 16bit, stero. Audio Compression is MPEG Layer 3: 96KBits, Stereo, 12Kb
Would like to get them all set to the above settings so that I can then edit Frame Rate to NTSC 23.976 with synced audio.
The error I mentioned occures with the Div3 and Microsoft Mpg4 V1-V2 codecs to the best of my knowledge, but not all the time.
Thank You in advance.
| Posted: Oct 8 2002, 06:45 PM |
DivX ;-) and MS MPEG-4 support odd video heights, but DivX 5.0.2 does not. What is the video size (width x height) of the videos which give you the error? (Choose VDub File->Information)
Also: * make sure that you have Video set to "Full processing mode." (duh) * look at Video->Color Depth, and make sure Output format is 24-bit.
I can't think of any other reasons you are getting error -2.
