Codec Isue ,removed From 1.10.4 :(
spatieman
Posted: Apr 7 2014, 08:38 AM
Hello.
I just want to now, how do i get my codex back in 1.10.4
i used 1.9.11 normaly, and used divx4.12 (latest version before it become payed xD)
and the X264vfw codec.
but in the laterst version they are both removed.
so i wonder, what do i need to do to get them back, i am not that good in finding out cli use..
Posted: Apr 7 2014, 11:55 AM
They're not removed, virtualdub only shows which codecs are installed on your pc
but.........
32bit virtualdub can only use 32bit codecs (virtualdub.exe)
64bit virtualdub can only use 64bit codecs (veedub64.exe)
So, did you get the same version as you used to have?
spatieman
Posted: Apr 8 2014, 07:48 AM
32 bit i guess,
virtualdub.exe
machine is 64bit ,
*edit*
when starting the 32 bit launcher, i see them xD
i gues divX4.12 is 32 bit only, but the x264vfw also ,hmm, need to check if there is 64bit version to,..
2 replies since Apr 7 2014, 08:38 AM Track this topic | Email this topic | Print this topic
