Flv 16:9 From Youtube Displayed Wrong
gvp
Posted: Feb 21 2014, 09:18 PM
Try this flv video (not mp4) ... http://www.youtube.com/watch?v=YHH2101OFfI
In virtualdub I get a picture like this
the right image is this
can anyone tell my why ?
I noticed the the problem occurs when the Display aspect ratio = 16:9 .... but i'm not 100% sure about that ...
ps
in vfw configuration i have enabled FLV1 and VP6F codecs.
Posted: Feb 21 2014, 10:25 PM
The normally happens when the width isn't a multiple of 4 (or 8)
You could try the ffmpeg input plugin instead and see if it's ok with that
Link's in my sig
All the plugins
http://forums.virtualdub.org/index.php?act...=ST&f=7&t=19488
Extract the contents to the plugins32 folder in virtualdub - both FFInputDriver.vdplugin and the ffdlls folder
To use the plugins
On the file menu, select open video file
Click on the video file you want to load so it is selected
Change the 'files of type' to the plugin you want to use
Now click OK
gvp
Posted: Feb 21 2014, 11:41 PM
thanks,
the problem was the http://moitah.net/download/latest/FLV_Input_Driver.zip.
FFMPeg Input Plugin works like a charm !!!
2 replies since Feb 21 2014, 09:18 PM Track this topic | Email this topic | Print this topic
