Libjpeg-turbo/turbojpeg Support
zcream
Posted: Dec 17 2013, 06:06 AM
Has anyone tried to include libjpeg-turbo/TurboJPEG support within virtualdub ?
I want to record 2x streams of 3K video in realtime - and this seems like a good candidate.
raffriff42
Posted: Jan 27 2014, 03:33 AM
Hi zcream, this library sounds interesting - although compiled-in support for it in VirtualDub is unlikely to happen. Someone would have to create a Video for Windows wrapper - that writes AVI files, since libjeg-turbo only writes images. The JPEG images *should* be muxable into an MJPEG AVI stream.
If external encoders become available in capture mode, there might be a way to use the command line cjpeg.exe:
Virtualdub.exe > BMP sequence > cjpeg.exe > JPEG sequence > ffmpeg.exe: mux to MJPEG AVI
But wait - why not try doing everything with command line tools? FFmpeg supports device capture:
device > ffmpeg.exe: capture > BMP sequence on RAMdisk  > cjpeg.exe > JPEG sequence > ffmpeg.exe: mux to MJPEG AVI
However moving all that data between processes might be slow; it might be faster to do everything with ffmpeg:
device > ffmpeg.exe: capture & write AVI
(for max speed you may want some other codec such as FFvHuff)
...just thinking out loud here...
1 replies since Dec 17 2013, 06:06 AM Track this topic | Email this topic | Print this topic
