X264 Codec In Virtualdub
Matteo
Posted: Oct 17 2013, 10:55 AM
Hi there guys, I'm Italian. First of all, my congrats for this forum, I've always looked for a site where I could find a good support for this great software... and now I found it! wink.gif
I need to capture keyframes from MKV's file, ripped in x264, with AVI's files I didn't have any problems, I just had to install XviD codec and it worked. But with MKV's files it seems a bit complicated: I've downloaded the Matroska plugin from here, placed it in the plugins folder and tried to open a MKV... no way, first appears the screen Parsing Matroska file, then I get this error.
Posted: Oct 17 2013, 12:57 PM
You have to do the same as you did with xvid and install the codec you need
X264vfw https://sourceforge.net/projects/x264vfw/files/
You'll need to do that with any codecs you need. If the audio is aac then there's a link for fcchandlers aac acm codec in my sig
Matteo
Posted: Oct 17 2013, 02:25 PM
Thanks dloneranger, now I can load properly MKV's files into VD. But each files I try to open has both AC3 and AAC audio track, why VirtualDub doesn't report anything? I didn't install the related plugins still.
Posted: Oct 17 2013, 02:55 PM
You'll get an error when you try to use an audio codec you haven't got installed (except in direct stream copy mode)
Links for both of those acm type codecs are in my sig
To pick between audio streams, use the menu -> audio ->source audio
Not sure what you want reported
You only get the missing codec error because virtualdub's trying to decode the video stream to display the first frame
You're not playing the audio though so there's no message
You can check your file information by the menu -> file -> file information
Matteo
Posted: Oct 17 2013, 03:08 PM
Ah, now I see... but I use VD only to capture keyframes, I need them for screenshots. So in theory, as I need the video only (for screens), I can do it without installing audio plugins... right?
Posted: Oct 17 2013, 03:15 PM
Yes, they're unneeded if virtualdub isn't actually trying to decode the audio
Matteo
Posted: Oct 17 2013, 03:48 PM
Thanks man, you've been really helpful, I thought it would be impossibile open MKV's files with VD.wink.gif
Posted: Oct 17 2013, 04:11 PM
(Just for anyone else reading or searching)
There's 4 ways
Three plugins -> Matroska, FFMpeg and Directshow found here http://forums.virtualdub.org/index.php?act...=ST&f=7&t=19488
And by an AVISynth script
Matteo
Posted: Dec 16 2013, 07:33 PM
Hi there, I'd have another problem with VirtualDub, it's similar to this, so I thought posting here, without opening a new thread.wink.gif
When I try to open an MP4 file, I get this error...
... the codec is always x264, but this time the container is MP4. How can I fix it? Is there another plugin I have to download?smile.gif
Posted: Dec 16 2013, 09:22 PM
You'll want one of these
Quicktime plugin - mov/mp4 etc
FFMpeg plugin - lots of file types
DirectShow plugin - lots of file types
Don't get the MP4 plugin, as that's outdated
from
Matteo
Posted: Dec 17 2013, 11:54 AM
You mean I have to get, in the page you linked, one of these?
* QuickTime / MPEG-4 / 3GPP (MOV MP4 M4V M4A QT 3GP 3G2 F4V) (by fccHandler)
* QuickTime / MPEG-4 / 3GPP (MOV HDMOV MP4 M4V M4A QT 3GP 3G2 F4V ...) (mod by ale5000 of tateu's one) => mostly superceded by fccHandler's one
* MPEG-4 / 3GPP (MP4 3GP)
But not the last one 'cause it's old?
Posted: Dec 17 2013, 01:52 PM
FccHandlers Quicktime plugin for mp4 and mov's is the better one - the links on that page don't work, but there's a two mirror's lower down the page and in my sig
Personally I'd just go with FFMeg plugin as it can load a lot of formats and it doesn't require external encoders either
Matteo
Posted: Dec 17 2013, 02:20 PM
Thanks man, you've been really helpful again. But all these procedures, codecs and so on aren't compatible with VirtualDubMod? I can do them only using VirtualDub?
-vdub-
Posted: Dec 17 2013, 10:20 PM
That's the first mention you have made for VirtualDubMod as this is Virtualdub forum the advice you have been given is for Virtualdub. You should have posted for VirtualDubMod in the VirtualDubMod forum
That said VirtualdubMod is now very old compared to the latest Virtualdub build, Virtuldub is the better choice. If you need VirtualDubMod for mkv encode you could use instead Virtualdub external encoders which can also to encode mkv and many other formats and containers. search the forum for example load scripts to use with Virtualdub External Encoders
I agree fcchandlers quicktime is better for avc1, h264, mp4 etc. Though maybe you would find FFMpeg Input Driver much easier to use for loading many different type of videos as dloneranger has stated. Which would load easily your mp4 file that likely is mp4 with avc1/aac - video/audio
Matteo
Posted: Dec 18 2013, 08:52 AM
QUOTE (-vdub- @ Dec 18 2013, 12:20 AM)
VirtualDub is perfect, now, with all plugins installed, it works great. The only reasons why I still use VirtualDubMod are:
- the Stream list feature, I often use it to grab the default audio for muxing and so on;
- the Snapshot source frame feature, I use it to capture screenshot.
For the first one, I don't see the equivalent in VirtualDub. The second one, there is a way but it's a bit "complicated", I have to select Copy source frame to clipboard, then I have to paste it in a graphic software, like Paint. Isn't there a way to capture them directly as in VirtualDubMod?
37 replies since Oct 17 2013, 10:55 AM Track this topic | Email this topic | Print this topic
Pages: (3) [1] 2 3
