| TGFbrigade |
| Posted: Jul 25 2013, 05:05 AM |
Hey guys, so I have a problem:
I am using Virtual Dub and have installed the K-lite mega pack codec. (found here: http://codecguide.com/download_kl.htm)
I am using this to try and compress large files that I've made through FRAPS. The problem is is that when I go to Video -> Compression, the codecs aren't listed (I believe it should be x264fvw or something?)
I am running Windows 7, 64-bit OS, I've tried uninstalling and redownloading both vdub and the codec pack.
Any idea what's going on? |
| Abrazo |
| Posted: Jul 25 2013, 07:12 PM |
For encoding to AVI in VirtualDub, you will need "video for windows" compatible codecs. Take care to install 32-bits versions of these codecs when you have installed VirtualDub 32-bit. Even so for 64-bits versions, must be equal.
You can find the x264vfw codec here: > http://sourceforge.net/projects/x264vfw/files/
After installation you should find it in VirtualDub's Video > Compression... dialogbox.
Look into this thread for a print screen of common settings (thanks to dloneranger): > http://forums.virtualdub.org/index.php?act...=ST&f=4&t=21157 |
| TGFbrigade |
| Posted: Jul 25 2013, 09:43 PM |
Thanks for the response. I installed that codec from the link you gave me, but I'm still not seeing it.
screen shot of the codec download: http://i.imgur.com/Nb8xbe3.jpg
screen shot of my vdub after the install is complete: http://i.imgur.com/oh6OCJm.jpg
I have the 64 bit vdub because I run a 64 bit OS (win 7). Would going down to the 32 bit one help me? I'm not incredibly knowledgeable about this stuff. |
| Posted: Jul 25 2013, 09:51 PM |
Yep, 32bit programs can only use 32bit codecs, 64bit programs can only use 64bit programs So it should all work as long as you get the same version of both Note: there are more codecs, filters and plugins available in 32bit versions only - and they'll run fine on a 64 bit OS
| TGFbrigade |
| Posted: Jul 25 2013, 10:10 PM |
Well I was downloading the 64 bit codec with the 64 bit vdub, on a 64 bit OS. I didn't think there would be any problems, but as those screen shots show, I'm still not seeing anything. Any idea why this might be happening? I'm pretty lost. |
| Posted: Jul 26 2013, 05:09 AM |
Sorry, but your screenshot don't show the 64bit version of x264vfw - the 64bit one is x264vfw64 Here's the link for both versions http://sourceforge.net/projects/x264vfw/files/
| 9of9 |
| Posted: Nov 3 2013, 01:28 AM |
I'm getting this very same issue. I'm on Windows 8.1 64-bit and I've installed both the 32-bit and 64-bit versions of the VfW codec and of VirtualDub, but I get nothing showing up in either of them.
Other codecs seem to work - I've gotten the LAME MP3 codec to come up just fine and I'm getting the ffdshow encoder coming up (although bizarrely it's only got four or five entries, I distinctly remember it having x264 options in the past too).
But I don't get why it wouldn't work, I've always used VDub with the VfW H264 encoder and it works great on all my other machines. I thought maybe it's a Windows 8 thing, but the OP on this thread seems to have had precisely this issue with Win7.
Anyone have any ideas? |
| Posted: Nov 3 2013, 11:40 AM |
ffdshow had most of it's encoders removed as they were iffy and they didn't want to keep supporting them x264vfw works fine on win7, 8 , 8.1 I can't think of any codecs that have issues, even the old ones installed fine for me if run as administrator Maybe you have a blank entry in your registry? Re: http://forums.virtualdub.org/index.php?act...=ST&f=3&t=14258 On 64 bit windows you'd have to check HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Drivers32] and HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432node\Microsoft\Windows NT\CurrentVersion\Drivers32]
