Cannot Install Aacacm Codec
jsallen
Posted: Mar 31 2013, 12:59 PM
Basic problem: .mp4 video from my GoPro camera loads but I get a message that the audio codec is missing.
The AACACM codec appears to be the one I need.
I downloaded AACACM.zip.
I tried to install both the 32-bit and 64-bit versions.
I get an error message, "Cannot copy to destination directory" (but doesn't say what directory that is).
When I click Retry, I am asked whether I want to skip files, and finally, "installation failed."
What directory is the installer trying to install to, and what is the problem? Maybe the directory is read-only?
Is there a manual install so I can discover the problem and get past it?
jsallen
Posted: Mar 31 2013, 01:35 PM
Ah, I think that I found it -- in a response to my same problem with a previous installation: I had to right click and click on "Run as administrator" in the ocnext menu.
There's a workflow issue here, and the error message could be more helpful.
Posted: Mar 31 2013, 03:13 PM
There's a link in my sig to that codec that I did an installer for, as well as some of the other codecs
2 replies since Mar 31 2013, 12:59 PM Track this topic | Email this topic | Print this topic
