Stuck On Vfw X.264/avc And Virtualdub
DragonZord
Posted: Jan 13 2013, 01:20 PM
I've installed the VFW X.264/AVC codec from Sourceforge, but I still can't open either format in Virtualdub. Please could someone offer some guidance? I suppose many people must have worked this out already. I'm on Win 7 x64.
I'm particularly interested in being able to open files made with Handbrake (x.264).
Thanks
Posted: Jan 13 2013, 04:00 PM
It is nothing more but a guess:
If you have installed the 32-bit version of VirtualDub, then you have to install the 32-bit version of the x264vfw codec.
You may not mix these versions. In case of, there is also a 64-bit version of the codec (v264vfw64):
> http://sourceforge.net/projects/x264vfw/files/
Interesting thread:
> http://forums.virtualdub.org/index.php?act...=ST&f=3&t=21364
Do you see the codec when you click in VirtualDub, on the Video-menu > Compression... ?
Do you get a particular error message ?
If you should need an AAC or AC3 audio codec for VirtualDub:
> http://gral.y0.pl/~fcchandler/
In case of difficulties with installation of these : use dloneranger versions:
> https://dl.dropbox.com/u/17024916/MyUploade...acm_X86_X64.zip
DragonZord
Posted: Jan 13 2013, 06:10 PM
Hi
Thanks for replying.
I have 32 bit version of both, and the codec does show up in Video > Compression so I imagine I can use it for encoding at least.
The error I get is "The file [...] is of an unknown or unsupported file type". I get this with all the h/x.264 files I've tried. Perhaps there's some way I can tell VirtualDub the type to try? The FourCC codes check out and match what X264VFW lists.
Thanks
Posted: Jan 13 2013, 06:25 PM
Wild guess, the file isn't an avi
If it's not, you'll need a plugin to handle it's file type
http://forums.virtualdub.org/index.php?act...=ST&f=7&t=19488
DragonZord
Posted: Jan 14 2013, 11:00 PM
Thanks! I installed all the filters from Fcchandler and now it opens :-)
I've missed Virtualdub. It's gonna be nice to be able to use it again biggrin.gif
4 replies since Jan 13 2013, 01:20 PM Track this topic | Email this topic | Print this topic
