Unable To Open Files In Virtualdub, H264 codec missing???
nietsbol
Posted: Nov 29 2012, 07:20 AM
Unable to open files in VirtualDub:
“Couldn’t locate decompressor for format ‘H264’ (unknown).
VirtualDub requires a Vidéeo for Windows (VFW) compatible codec to decompress video.DirectShow codec…are not suitable”
Issue appears since to days. Works fine before..
Thanks for help
Posted: Nov 29 2012, 05:09 PM
You'll need a codec capable or understanding H264
http://sourceforge.net/projects/x264vfw/files/
(either your previous videos did not use H264 or it somehow became uninstalled)
nietsbol
Posted: Dec 1 2012, 10:30 AM
Thank you, issue solved...
friscom
Posted: Jan 10 2013, 08:20 AM
I followed dloneranger's suggestion and downloaded the indicated file and installed the DLL both into VirtualDub Directory and also into the System32 one (my OS is Windows7 ultimate, 64 bit)
I still get the message reported in the initial post.
Any useful hint how to solve this issue?
thanks in advance!
Posted: Jan 10 2013, 02:16 PM
Um, it's not a dll, it's an installer
Download and run it, then start virtualdub and it should be in the list
(Can't remember if it needs to be 'run as admin' offhand)
4 replies since Nov 29 2012, 07:20 AM Track this topic | Email this topic | Print this topic
