Nero Help, Help
Crash n Burn
Posted: Feb 14 2004, 08:31 PM
When i start it up i click on compile new cd then video cd.I drag over the mpeg.Then i click on burn to cd.But instead of burning it to a cd it saves an image file to the hard drive.
what do i do?
AhnDoum
Posted: Feb 14 2004, 09:14 PM
That is happening because the current device selected is Image Recorder, you have to set it to your CD-Writer. If you have nero 6 u can see it at the center top of the window, if you have an older version search the menu for CHOOSE RECORDER.
Hope it helped.
Crash n Burn
Posted: Feb 15 2004, 03:07 AM
But when i click on choose recorder my CD drive isnt there.It just shows the image recorder?
LeoGetz
Posted: Feb 15 2004, 04:52 AM
What version of Nero are u using?
I'm using v5.5.10.35 and under recorder lists your available recorder options...
Tried v6... but didn't like it. Everytime I put a new cd in, the recoding name of last cd I did would come up a name for my new cd. instead of 'New'... so I went back to a version I had no problems with...
Crash n Burn
Posted: Feb 15 2004, 06:06 PM
Its V5.5.5.1
LeoGetz
Posted: Feb 18 2004, 07:07 PM
you could always use a P2P file shareing program and do a search for a newer version of Nero. I no longer have that version so I wouldn't know much about its faults.
You could also download the latest trial of Nero from their site (www.nero.com) and try it. Chances are that your burner might be of a newer model and at the time v5.5.5.1 came out your burner might not have been listed in their database.
Cyberman
Posted: Feb 18 2004, 11:52 PM
QUOTE (Crash n Burn @ Feb 15 2004, 04:07 AM)
I have to ask - you mean CD Writer, or Burner or something, right?
Matroska/MKV ?
6 replies since Feb 14 2004, 08:31 PM Track this topic | Email this topic | Print this topic
<< Back to Off-Topic
