Mov Video Artefacts
ZTolerance
  Posted: Sep 5 2014, 07:21 PM
Hello. Sorry if I select wrong section for this thread.
I use VD 1.10.4 with "QuickTime.vdplugin" plugin for MOV video import (action camera).
So, I open video and got artefacts on almost every frame:
http://4.firepic.org/4/images/2014-09/05/u...aeraongn32d.jpg
http://4.firepic.org/4/images/2014-09/05/r...69xic3m8nvy.jpg
How to fix it?
Posted: Sep 5 2014, 07:59 PM
The QuickTime plugin itself can open MP4 and MOV containterformats, but depends of an audio- (AAC) and a video- (H264) decoder.
When you actually open an MP4 and look into File > File information... you will probably detect a video-decoder that is not able to read the video correctly.
So, a number of steps to follow:
First, be sure that you downloaded and installed the QuickTime plugin from FccHandler (because there is also an other, older version):
> http://sourceforge.net/projects/fcchandler...ktime%20Plugin/
Second, download and install the x264vfw (H264/AVC-1) video-codec:
> http://sourceforge.net/projects/x264vfw/files/x264vfw/
Third, download and install the AacACM audio-codec (= not the AC3, but AAC. So take care to make the correct choice):
> http://sourceforge.net/projects/fcchandler.../?source=navbar
This codec is available in a ZIP with *.inf or *.bat installer (aacacm v1.9.zip), and also with an *.exe installer (SetupAACacm_X86_X64.zip)
After this, audio and video decoding should be alright when opening MP4 via the QuickTime plugin in VirtualDub.
Alternatives for this are the DirectShow plugin:
> http://forums.virtualdub.org/index.php?act...=ST&f=7&t=15093
and the FFMpeg plugin:
> https://sourceforge.net/projects/virtualdub...peginputplugin/
ZTolerance
Posted: Sep 5 2014, 09:23 PM
Ok, download VD (clean).
Download "quicktime.zip" (http://sourceforge.net/projects/fcchandler/files/Virtualdub%20Quicktime%20Plugin/). Copy "QuickTime.vdplugin" in "plugins32".
Download "AacAcm Codec/aacacm v1.9.zip" (http://sourceforge.net/projects/fcchandler/files/?source=navbar) and run "Install the 32-bit codec.bat" by Administrator.
x264vfw already installed in system.
Run VD, open MOV and got same artefacts sad.gif.
Video Info:
Video: MPEG4 Video (H264) 1280x720 30fps 13108kbps [V: DataHandler [eng] (h264 main L4.0, yuv420p, 1280x720, 13108 kb/s)]
Audio: PCM 32000Hz mono 512kbps [A: DataHandler [eng] (pcm_s16le, 32000 Hz, 1 channels, s16, 512 kb/s)]
General
Complete name                  : D:\video\action\17530001.MOV
Format                         : MPEG-4
Format profile                 : QuickTime
Codec ID                       : qt
File size                      : 892 MiB
Duration                       : 8mn 43s
Overall bit rate               : 14.3 Mbps
Encoded date                   : UTC 2004-01-01 00:00:00
Tagged date                    : UTC 2004-01-01 00:00:00
Video
Format                         : AVC
Format/Info                    : Advanced Video Codec
Format profile                 : Main@L4.0
Format settings, CABAC         : No
Format settings, ReFrames      : 1 frame
Codec ID                       : avc1
Codec ID/Info                  : Advanced Video Coding
Duration                       : 8mn 43s
Bit rate                       : 13.1 Mbps
Width                          : 1 280 pixels
Height                         : 720 pixels
Display aspect ratio           : 16:9
Frame rate mode                : Constant
Frame rate                     : 30.000 fps
Color space                    : YUV
Chroma subsampling             : 4:2:0
Bit depth                      : 8 bits
Scan type                      : Progressive
Bits/(Pixel*Frame)             : 0.474
Stream size                    : 818 MiB (92%)
Language                       : English
Audio
Format                         : PCM
Format settings, Endianness    : Little
Format settings, Sign          : Signed
Codec ID                       : sowt
Duration                       : 8mn 43s
Bit rate mode                  : Constant
Bit rate                       : 512 Kbps
Channel(s)                     : 1 channel
Sampling rate                  : 32.0 KHz
Bit depth                      : 16 bits
Stream size                    : 32.0 MiB (4%)
Language                       : English
raffriff42
Posted: Sep 6 2014, 02:14 AM
See the FFMpeg plugin Abrazo has linked to, I think it may work better.
It's possible your file is corrupt - that's what it looks like. Before we can say for sure, we need to eliminate the decoder as a possible cause of the artifacts. (Have you viewed the video successfully on any other program? Which ones?)
ZTolerance
Posted: Sep 6 2014, 11:32 AM
Yeah! I install "FFInputDriver.vdplugin" and remove "QuickTime.vdplugin" — and it's works (artefacts disappeared).
Maybe file is corrupt little bit. When I select 720P quality on my action-camera (SJ4000), then I got this artefacts, in 1080P quality all is fine. But Media Player Classic (with K-Lite) play any video without artefacts ("FFInputDriver.vdplugin" too).
Thank you guys, solved.
4 replies since Sep 5 2014, 07:21 PM Track this topic | Email this topic | Print this topic
<< Back to General Discussion
