| ihope |
| Posted: Jul 17 2014, 08:46 AM |
Hello,
I have a question about cropping in virtual dub and aspect ratio of the final video.
I have a PAL Video (720*576) (SAR : 1,25 / PAR : 1,33 /DAR : 4/3 = 1,33) i want to convert in mp4 file.
If I crop this video (10 pixel bottom and top and 6 pixels left and right) how virtual dub will manage the aspect ratio?
I mean : - The SAR of my video change : 700 * 564 (SAR : 1,24) - The PAR of my video don't change (The pixel ratio in final is always 1,33) => So the DAR of my video change : DAR = PAR * SAR = 1,33 * 1,24 = 1,65
Does Virtual Dub will manage this correctly? If VirtualDub don't correct this the risk is the player base the display on DAR and will show the video in 4/3 so this will be not correct !!!!!!!! |
| malky |
| Posted: Jul 17 2014, 10:34 AM |
If the source is 720x576 and is cropped 10+10 from top/bottom and 6+6 left/right, surely it's now 708x556 - you say it's 700x564?
I think after cropping, if it's resized back to the original size and since mp4 uses square pixels, the new sar times the new par (1:1) the dar is back to 4:3. |
| ihope |
| Posted: Jul 17 2014, 11:31 AM |
I would encode in H264. => I want delete 10 pixels left right and 6 top/bottom (mistake in my post).
I want just crop no resize (will affct the image ...) I just want vdub crop the pixels and correct the DAR for the video display correctly by player in case DAR is used (or perhaps all players are using PAR?, i don't know) ... |
| Posted: Jul 17 2014, 12:33 PM |
dar and par are not set by virtualdub - any settings related to those are in the codecs's settings (or codecs and muxer if using external encoders)
| ihope |
| Posted: Jul 17 2014, 02:43 PM |
Virtual dub don't send the aspect ratio to the codec? |
| Posted: Jul 17 2014, 04:14 PM |
There's no way to do it Each codec (and/or muxer) has it's own way of setting it, and many can't at all The same way that virtualdub doesn't send the 'quality' to an encoder - you have to set it in the encoder itself
