| mark pigott |
| Posted: Jun 26 2014, 04:42 PM |
I have set up some files that I though would auto append:
the syntax was 01 opening logo 02 june 5 03 june 7 04 june 9
etccccc.....
you'd think virtual dub would see this sequence but if I load 01 opening logo and click on append, it will only append 02 to the end.....
what am i missing here???? |
| raffriff42 |
| Posted: Jun 26 2014, 09:14 PM |
The files have to be numbered sequentially like this: hello.000.avi hello.001.avi hello.002.avi etc...
I'm not absolutely sure the red dots are needed; the main thing is, the names should all be the same, except for the serial numbers at the end.
There are batch file renaming utilities available to do this. One of them is IrfanView, which you might have on your system already. I made a guide for batch renaming with IrfanView, here. |
