| ADelm |
| Posted: Mar 19 2014, 01:27 PM |
Hi!
When I do [File / Open Video Files] in a folder having 44 pictures, only 30 are loaded.
Searching the forums, this question was already asked, but the answer given do not solve the problem.
I am using: - Windows 7 Family Edition Premium x64, display resolution 1600x900 - Virtualdub 1.10.4 (also tested with virtualdub 1.9.6 Fr instalable) - png pictures (also tested with .jpg pictures).
Thanks for any help
Alain |
| Posted: Mar 19 2014, 04:24 PM |
Which answers were those?
Usual answers 1) the file name numbers have a gap -eg 1,2,3,5,6,7 2) there's a file that virtualdub doesn't like - try loading the file that should be next into virtualdub and see if it's ok
| Abrazo |
| Posted: Mar 19 2014, 07:21 PM |
3) pictures should all have equal dimensions (for exemple 1600 x 900); maybe there are one of more pictures with a few pixels more or less. |
| ADelm |
| Posted: Mar 22 2014, 10:04 AM |
Thanks for the answers. The problem was 1) the sequence had missing numbers.
Thanks again
-- Alain |
