Virtualdub Problem, VirtualDub doesn't work
andrewdessi
Posted: Jan 26 2014, 05:29 PM
Hi to everyone! When I open video file (.avs extension) with VirtualDub it doesn't work. When I try to select the useless scenes clicking on the starting and the ending point VirtualDub stops and I can't cut these scenes. I have tried to refresh VirtualDub and Operating System with but it doesn't work too. I could work without these problems with VirtualDub this morning. How to fix this problem? Thank you very much.
raffriff42
Posted: Jan 26 2014, 06:48 PM
Home key=set start of selection; End key=set end of selection
Encode only part of a video:
Go to first good frame, press {Home} key
Go to last good frame, {End}
File, Save as AVI
Delete footage:
Go to first bad frame, {Home}
Go to last bad frame, {End}
Edit menu, Delete
Move footage:
First, {Home}
Last, {End}
Edit menu, Cut
Go to insert position
Edit menu, Paste
Raffriff's 'Awesome' Virtualdub tutorial
1 replies since Jan 26 2014, 05:29 PM Track this topic | Email this topic | Print this topic
