| rsg426 |
| Posted: Dec 27 2013, 01:54 AM |
Hello,
I am pasting my crash report. The scenario of what I am trying to do is as follows:
I have a AVI file that I have extracted out of Camtasia Studio, It is approximately 25.9 GB. The issue I am having is at around 55 minutes the video error outs, I think the recorder started dropping frames and the file got corrupted. I have tried encoding the file as an mp4 in handbrake but ran into the same issue, around 55 min the video error outs. I have tried various encoding programs and "video repair software" with no luck. I came across your software and was wondering if you could run me through some instructions on re-encoding based on the scenario before. I was able to export a video with the techsmith capture codec 2 but ran into the same issue. Looking forward to your response.
The below error happens when I try to Mark In/Mark Out from the 55 minute point onward
VirtualDub crash report -- build 35491 (release-AMD64) --------------------------------------
Disassembly: 7feec122f20: 410fb602 movzx eax, byte ptr [r10] 7feec122f24: 49ffc1 inc rcx 7feec122f27: 49ffc2 inc rdx 7feec122f2a: 6603ce add ecx, si 7feec122f2d: 418841ff mov [r9-01h], al 7feec122f31: 75ed jnz ec122f20 7feec122f33: e978ffffff jmp ec122eb0 7feec122f38: 450fb602 movzx eax, byte ptr [r10] 7feec122f3c: 410fb65201 movzx edx, byte ptr [r10+01h] 7feec122f41: 0fb7c7 movzx eax, bh 7feec122f44: 438d0c40 lea ecx, [r8+r8*2] 7feec122f48: 4983c202 add rdx, 02h 7feec122f4c: 0fafd0 imul edx, eax 7feec122f4f: 03d1 add edx, ecx 7feec122f51: 8bc2 mov eax, edx 7feec122f53: 4c03c8 add ecx, eax 7feec122f56: 664103d8 add ebx, ax 7feec122f5a: e951ffffff jmp ec122eb0 7feec122f5f: 0fb7c3 movzx eax, bl 7feec122f62: 8bdd mov ebx, ebp 7feec122f64: 8d0c40 lea ecx, [rax+rax*2] 7feec122f67: 0fb7c7 movzx eax, bh 7feec122f6a: 2bc1 sub eax, ecx 7feec122f6c: 4898 cwde 7feec122f6e: 4c03c8 add ecx, eax 7feec122f71: e93affffff jmp ec122eb0 7feec122f76: 450fb64202 movzx eax, byte ptr [r10+02h] 7feec122f7b: 450fb65a03 movzx ebx, byte ptr [r10+03h] 7feec122f80: 0fb6c1 movzx eax, cl 7feec122f83: 6603d8 add ebx, ax 7feec122f86: 4983c204 add rdx, 04h 7feec122f8a: 84c9 test cl, cl 7feec122f8c: 0f841effffff jz ec122eb0 7feec122f92: 6666666666660f db 0fh 7feec122f99: 1f db 1fh 7feec122f9a: 8400 test [rax], al 7feec122f9c: 0000 add [rax], al 7feec122f9e: 0000 add [rax], al 7feec122fa0: 418811 mov [r9], dl <-- FAULT 7feec122fa3: 45884101 mov [r9+01h], al 7feec122fa7: 45885902 mov [r9+02h], bl 7feec122fab: 4983c103 add rcx, 03h 7feec122faf: fec9 dec cl 7feec122fb1: 75ed jnz ec122fa0 7feec122fb3: e9f8feffff jmp ec122eb0 7feec122fb8: 488b5c2408 mov rbx, [rsp+08h] 7feec122fbd: 488b6c2410 mov rbp, [rsp+10h] 7feec122fc2: 488b742418 mov rsi, [rsp+18h] 7feec122fc7: 488b7c2420 mov rdi, [rsp+20h] 7feec122fcc: c3 ret 7feec122fcd: cc int 3 7feec122fce: cc int 3 7feec122fcf: cc int 3 7feec122fd0: cc int 3 7feec122fd1: cc int 3 7feec122fd2: cc int 3 7feec122fd3: cc int 3 7feec122fd4: cc int 3 7feec122fd5: cc int 3 7feec122fd6: cc int 3 7feec122fd7: cc int 3 7feec122fd8: cc int 3 7feec122fd9: cc int 3 7feec122fda: cc int 3 7feec122fdb: cc int 3 7feec122fdc: cc int 3 7feec122fdd: cc int 3 7feec122fde: cc int 3 7feec122fdf: cc int 3 7feec122fe0: cc int 3 7feec122fe1: cc int 3 7feec122fe2: cc int 3 7feec122fe3: cc int 3 7feec122fe4: cc int 3 7feec122fe5: cc int 3 7feec122fe6: cc int 3 7feec122fe7: cc int 3 7feec122fe8: cc int 3 7feec122fe9: cc int 3 7feec122fea: cc int 3 7feec122feb: cc int 3 7feec122fec: cc int 3 7feec122fed: cc int 3 7feec122fee: cc int 3 7feec122fef: cc int 3 7feec122ff0: cc int 3 7feec122ff1: cc int 3 7feec122ff2: cc int 3 7feec122ff3: cc int 3 7feec122ff4: cc int 3 7feec122ff5: cc int 3 7feec122ff6: cc int 3 7feec122ff7: cc int 3 7feec122ff8: cc int 3 7feec122ff9: cc int 3 7feec122ffa: cc int 3 7feec122ffb: cc int 3 7feec122ffc: cc int 3 7feec122ffd: cc int 3 7feec122ffe: cc int 3 7feec122fff: cc int 3 7feec123000: cc int 3 7feec123001: cc int 3 7feec123002: cc int 3 7feec123003: cc int 3 7feec123004: cc int 3 7feec123005: cc int 3 7feec123006: cc int 3 7feec123007: cc int 3 7feec123008: cc int 3 7feec123009: cc int 3 7feec12300a: cc int 3 7feec12300b: cc int 3 7feec12300c: cc int 3 7feec12300d: cc int 3 7feec12300e: cc int 3 7feec12300f: cc int 3 7feec123010: cc int 3 7feec123011: cc int 3 7feec123012: cc int 3 7feec123013: cc int 3 7feec123014: cc int 3 7feec123015: cc int 3 7feec123016: cc int 3 7feec123017: cc int 3 7feec123018: cc int 3 7feec123019: cc int 3 7feec12301a: cc int 3 7feec12301b: cc int 3 7feec12301c: cc int 3 7feec12301d: cc int 3 7feec12301e: cc int 3 7feec12301f: cc int 3
Built on Althena on Sun Oct 27 16:00:02 2013 using compiler version 1400
Windows 6.1 (Windows 7 x64 build 7601) [Service Pack 1] Memory status: virtual free 8388346M/8388608M, commit limit 16380M, physical total 8191M
RAX = 37 RBX = 37 RCX = 37 RDX = cb RSI = ffff RDI = 1004 RBP = 0 R8 = 4 R9 = 5161080 R10 = 8146b08 R11 = 80 R12 = 20df0e0 R13 = 8140040 R14 = 4d60080 R15 = 600c00 RSP = 12f2d8 RIP = 7feec122fa0 EFLAGS = 00010202
Crash context: An out-of-bounds memory access (access violation) occurred in module 'Veedub64'...
...writing address 0000000005161080...
...while decompressing video frame 121537 (VideoSource.cpp:2155)...
...while using input buffer at 0000000008140040-0000000008140041 (VideoSource.cpp:2154)...
...while using output buffer at 0000000004D60080-0000000005160883 (VideoSource.cpp:2153).
Pointer dumps:
RSP 0012f2d8: ec126157 000007fe 0012f370 00000000 020de460 00000000 00000002 00000000 0012f2f8: 04449600 00000000 0000400d 00000000 ec2337c8 000007fe 0012f370 00000000 0012f318: 0012f370 00000000 020de430 00000000 fd4a1a7a 000007fe 00000030 00000000 0012f338: 000003d7 00000000 28000000 00000000 ec233cf0 000007fe 020e34e0 00000000 R10 08146b08: 00000000 80000000 00000000 8001a513 00000000 80017fc0 00000000 8002ae48 R12 020df0e0: 00690056 00650064 0020006f 006f0063 00650064 00200063 00540022 00630065 R13 08140040: a5a50002 a5a5a5a5 a5a5a5a5 a5a5a5a5 0000a5a5 00000000 00000000 80067c03 R14 04d60080: 00a5a500 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5
Thread call stack: 7feec122fa0: tsccvid64!DriverProc [7feec120000+1118+1e88] 7feec126157: tsccvid64!DriverProc [7feec120000+1118+503f] 7feec2337c8: MSVFW32!ICSendMessage [7feec230000+3770+58] 7fefd4a1a7a: KERNELBASE!ReadFile [7fefd4a0000+1a00+7a] 7feec233cf0: MSVFW32!ICDecompress [7feec230000+3cac+44] 140275b1b: VDVideoDecompressorVCM::DecompressFrame() 140184885: VDFile::readData() 140153942: VideoSourceAVI::streamGetFrame() 14015256f: VideoSourceAVI::streamFillDecodePadding() 1400535af: VDFilterFrameVideoSource::RunRequests() 77469bef: USER32!TranslateMessageEx [77450000+19930+2bf] 140050c94: VDFilterFrameManualSource::CreateRequest() 14006475b: FilterSystem::RequestFrame() 1400a238e: VDProject::DisplayFrame() 1400ad177: VDProjectUI::UICurrentPositionUpdated() 14009e2b5: VDProject::MoveToFrame() 1400a9f2b: VDProjectUI::OnPositionNotify() 1400b5508: VDProjectUI::MainWndProc() 7feec2337c8: MSVFW32!ICSendMessage [7feec230000+3770+58] 7fefd4a1a7a: KERNELBASE!ReadFile [7fefd4a0000+1a00+7a] 7feec233cf0: MSVFW32!ICDecompress [7feec230000+3cac+44] 77469aa6: USER32!TranslateMessageEx [77450000+19930+176] 774637e2: USER32!GetWindowLongPtrA [77450000+137c0+22] 1400c9695: VDUIFrame::StaticWndProc() 140184885: VDFile::readData() 77469bd1: USER32!TranslateMessageEx [77450000+19930+2a1] 1401539a4: VideoSourceAVI::streamGetFrame() 77469b43: USER32!TranslateMessageEx [77450000+19930+213] 77466aa8: USER32!SetTimer [77450000+16930+178] 7745d398: USER32!SendMessageA [77450000+d338+60] 7746542a: USER32!GetWindowLongA [77450000+15408+22] 140113ab9: VDPositionControlW32::Notify() 14017bb81: VDRoundToInt64() 14011464b: VDPositionControlW32::WndProc() 774637e2: USER32!GetWindowLongPtrA [77450000+137c0+22] 140114e92: VDPositionControlW32::StaticWndProc() 77469bd1: USER32!TranslateMessageEx [77450000+19930+2a1] 77469b43: USER32!TranslateMessageEx [77450000+19930+213] 774698da: USER32!TranslateMessage [77450000+196f0+1ea] 77469712: USER32!TranslateMessage [77450000+196f0+22] 140086c0e: inMain() 1402977c1: _tmainCRTStartup() 7734652d: kernel32!BaseThreadInitThunk [77330000+16520+d] 7757c541: ntdll!RtlUserThreadStart [77550000+2c520+21]
-- End of report |
| Posted: Dec 27 2013, 02:18 AM |
That's the 'TechSmith Screen Capture Codec' crashing while trying to read the file
You could try the 32bit version of video editors to see if it's just a problem with the 64bit codec
If that doesn't work, you could try just skipping that frame and some of the following ones to see if you can get past that error (it may be a glitch at that point, or everything after that is borked)
