(1.5.4) Default Codec, Messages, Huffyuv instead of RBG, Warn again
Cyberman
Posted: Oct 28 2003, 11:13 AM
I think it would be useful if VDub selected Huffyuv by default(if installed, of course). Just yesterday I was cutting a video and accidently didnīt set to DSC. Thus is was compressed as uncompressed RGB. Since the video was short anyway, it didnīt matter, but when I wanted to append I couldnīt.
Itīs no big problem, but itīs annoying - I think this could be solved if VDub uses Huffyuv by default - Iīm sure that anyone whoīs seriously editing videos would use it anyway.
Second: Bring back the warning messages for uncompressed - theyīre apparently more important than they look.
(Note: Iīm using 1.5.4 - so maybe thatīs already done)
Matroska/MKV ?
allstrox
  Posted: Oct 29 2003, 05:06 PM
I think VirtualDub should select the last used codec for both video and audio compression.
I believe almost all users would agree that saving as uncompressed rgb is a very rarely used feature. So why should that be the default?
i4004
Posted: Oct 29 2003, 05:58 PM
the stuff you guys talk about can be done thru so-called "save processing settings" feature.....
prior to anything,just load it up and there,everything as you like it.........
"default" is "do-nothing" and that's uncompressed rgb.....
bah.......
my signature:
Cyberman
Posted: Oct 29 2003, 07:49 PM
The last used codec wonīt be any help for me - I agree that it is useful, but when Iīm working on a video, I have to compress it sometimes, to have a better look. (WHen using Huffyuv, I canīt be sure the video plays as smooth as it should).
I know about the processing settings - but thatīs almost as much work as selecting it. Itīs useful when using several filters, but just for codec? Doesnīt pay off IMO.
Thus I recommend using Huffyuv as default, instead of uncompressed.
And, no - default is not "dö-nothing" itīs "decompress but donīt recompress".
Matroska/MKV ?
i4004
Posted: Oct 29 2003, 09:27 PM
luckily for you,avery read it and just forgot it..( smile.gif )
c'mon guys,this is not a serious problem,is it....
also...why should ANY codec be installed via vdub?
i almost never use huff,so how would this work for me?
if someone doesn't have huff installed,would you answer every post here?
my signature:
Cyberman
Posted: Oct 30 2003, 09:16 AM
No, itīs not a serious problem, but since most of us ran out of those - well, now only the not-so-serious problems appear ;-)
If Huffy isnīt installed, then donīt select it - it could revert to RGB in that case.
You donīt use Huffyuv? Interesting - Iīd thought that most people use it - maybe Iīm wrong.
Whenever I edit a video(i.e. cutting AND processing via filters), I switch to Huffyuv, thatīs why I recommended that.
Matroska/MKV ?
i4004
Posted: Oct 30 2003, 06:55 PM
heard of frameserving?
avs?
me lack hdd space for huff.......
my signature:
Cyberman
Posted: Apr 17 2004, 09:23 PM
Sorry to bump the old thread up, but I just had that problem again. I saved the file and went away(it took "only" 5 minutes, but itīs boring to watch the computer), but when I came back I got an error message that thereīs not enough HDD space to continue - although I KNEW there were at least 6Gigs left.
Guess the problem! - Right - uncompressed RGB. Since I just previously edited the file(and saved it), I closed VDub(to reset all settings - that way I canīt forget anything) and loaded the new file.
Set the filters - and let it work. But forget to set the codec, again.
I know itīs my fault, not VDubīs - but if it, as I said in the first post, selected Huffyuv by default(maybe making it a parameter?), it wouldnīt have occured.
Matroska/MKV ?
3dlover
Posted: Jan 23 2013, 05:39 PM
I can't believe that I'm bumping a 10 year old thread.... But I could really use a simple option in the program preferences to set a default codec for both video and audio. I primarily use VDub to compile up image sequences, and most of the time I want to compile to the same codec. I know that I could use the load processing settings, but remembering to do this every time I launch VDub is not really any different than remembering to change codecs every time.
Thanks!
Posted: Jan 23 2013, 06:29 PM
Save your favorite processing settings
Create a shortcut to virtualdub
Right click the shortcut and select properties
At the end of the target line add something like this - change the path to your saved settings
/s "C:\Users\Public\Documents\X264.vdscript"
(there's a space before the /s)
When started from the shortcut it'll load those settings
Not sure if that will work with virtualdubmod
If it doesn't then you're out of luck as you'll get a new version shortly after the end of the universe
9 replies since Oct 28 2003, 11:13 AM Track this topic | Email this topic | Print this topic
