[suggestion] Ppm Frame Import
Videogamer555
Posted: Dec 13 2012, 04:30 AM
Portable Pix Map is a fairly standard format (though not as much as PNG), and VDub should be support importing PPM images as video frames (just like it already supports BMP, PNG, etc). I have a physics sim game with built in screen recording feature. However instead of exporting all frames to a single AVI file, it exports each one to a separate file, and that file format is binary PPM (as opposed to the other variety which is all ascii text). For some reason they don't use the more standard BMP file for these images. I've contacted this software's developer and asked him recode the screen recording function to output BMP instead, but he INSISTS on sticking with PPM. So to compile these into an AVI video I'll need either Virtualdub's frame loader to have the capability added to it to be able to load PPM images, or I'll have to get all the images converted in another program, prior to importing them as frames in virtualdub. However if it is a two step process (convert then make AVI) it will take twice as long as if it could just natively load PPM images.
I know this is called the Unofficial VirtualDub Support Forums, but I'm hoping that the devs periodically read the stuff here for new ideas.
Posted: Dec 13 2012, 06:28 AM
This is the developers board, and he answered the last time you posted the question
http://forums.virtualdub.org/index.php?act...&t=21283&hl=ppm
It's a really rare format for windows (I've never seen one of those files at all)
I could find something that will convert them though (free)
http://gnuwin32.sourceforge.net/packages/netpbm.htm
It'll convert from ppm to many different formats
http://netpbm.sourceforge.net/doc/directory.html
Hope that helps
1 replies since Dec 13 2012, 04:30 AM Track this topic | Email this topic | Print this topic
