| Spire |
| Posted: Sep 5 2002, 01:06 AM |
Hi everybody! Long-time VirtualDub user here.
For my first post, I'd like to submit a fix for a relatively minor cosmetic bug affecting VirtualDub 1.4.10 as well as previous versions. It affects the very small percentage of users who have calibrated their displays to use a non-standard DPI setting (i.e., not 96DPI or 120DPI).
When the display is set to a custom DPI, the information panel text in the position control appears in the wrong font size. On my system, which is calibrated to 135DPI, the text in the information panel is unreadably small.
Fortunately, the fix is easy and simple. In the source file PositionControl.cpp, delete line 276:
| CODE | | pcd->hFont = CreateFont(8, 0, 0, 0, FW_DONTCARE, FALSE, FALSE, FALSE, DEFAULT_CHARSET, OUT_DEFAULT_PRECIS, CLIP_DEFAULT_PRECIS, DEFAULT_QUALITY, DEFAULT_PITCH | FF_DONTCARE, "MS Sans Serif"); |
...and replace it with the following code:| CODE | if (!(pcd->hFont = (HFONT) GetStockObject(DEFAULT_GUI_FONT))) { NONCLIENTMETRICS ncm = { sizeof(ncm) }; SystemParametersInfo(SPI_GETNONCLIENTMETRICS, sizeof(ncm), &ncm, 0); pcd->hFont = CreateFontIndirect(&ncm.lfMessageFont); } |
I also noticed a minor resource leak bug related to this one that can be fixed if desired. In the same source file, search for the following two lines (they're line 337 and 338 in the original unedited file):| CODE | case WM_DESTROY: delete pcd; |
In between these two lines, insert the following line:| CODE | | if (pcd->hFont) (DeleteObject(pcd->hFont); |
Then recompile and add water.
That's it! I'm sure there are lots of tiny resource leaks like this one scattered throughout the VirtualDub source code, but they are pretty much inconsequential and nothing to worry about. It's mainly the cosmetic problem that I wanted to fix. |
| SillKotscha |
| Posted: Sep 5 2002, 01:11 AM |
smart Moderator
although I haven't any idea about 'how to (re)compile' your input is highly appreciated...
kind regards - Sill
| Spire |
| Posted: Sep 5 2002, 01:37 AM |
Hi Sill,
To compile VirtualDub, you need Microsoft Visual C++, and of course the VirtualDub source code. Instructions are included with the source code.
It would be nice if Avery simply folded this fix into the next release of VirtualDub so that everyone can benefit.
I have other UI fixes that I've done on my own personal build of VirtualDub, and I'll try to post them if there is any interest. |
| Ciler |
| Posted: Sep 5 2002, 06:06 AM |
| QUOTE (Spire @ Sep 4 2002, 07:37 PM) | Hi Sill,
Please do, this is a really valuable input IMO |
| ChristianHJW |
| Posted: Sep 5 2002, 12:19 PM |
In fact i will talk to everwicked about the creation of a new sector for this .... i never thought the board could be used for such a valuable purpose also !!
| Posted: Sep 15 2002, 10:39 PM |
Thanks for the fix, but a couple of comments. First, everyone in the system is pretty much screwed if GetStockObject(DEFAULT_GUI_FONT) fails; odds are slim to none that CreateFontIndirect() will work. In that case, it's better simply to not set the font and have the controls use their own default. Second, the font is still selected into the child controls when WM_DESTROY arrives, so the DeleteObject() is too early -- I'll probably move the delete to WM_NCDESTROY, as that is called after all child windows are destroyed. |
