Avisynth 2.5.5 Released!, AviSynth 2.5.5 Released!
sh0dan
Posted: Sep 1 2004, 03:31 PM
Avisynth Developer
Hi everybody!
So finally there is a new AviSynth version for you!
The complete changelist from version 2.54 is below:
Additions:
* Added TCPDeliver, which enables video to be served via local network.
* Added a huge list of ColorPresets, that can be used instead of colors (which can be found in the plugins folder: colors_rgb.avsi).
* Added: BlankClip now has color_yuv, that allows setting and YUV color for YUV clips.
* Added AssumeFPS(clip1, clip2 [, sync_audio=true/false]) (stickboy again)
* Added audio=true/false to SelectRangeEvery. This will optionally also cut up audio according to the select. Default: true.
* Added Turn180()
* Added FrameRateNumerator() and FrameRateDenominator() as clip properties.
* Added AudioLenghtF() as clip property.
* Added IsAudioFloat() and IsAudioInt() as clip properties.
* Added experimental "after_frame=true/false" to ScriptClip.
* Added FOURCC parameter to AviSource by stickboy.
* Added Lanczos4Resize().
* Added french documentation.
* Added float audio and multiple channels support to Dissolve.
* Added WriteFile, WriteFileIf, WriteFileStart, WriteFileEnd. (WarpE)
* Added dll-name prefix to plugins as per http://forum.doom9.org/showthread.php?s=&t...&threadid=72235.
o o Syntax is DLLNAME_function(), where DLLNAME is the filename of the dll containing the function.
* Added automatic audio cache.
* Added CPU stuff to Info().
* Added GeneralConvolution divisor.
* Added audio cache after EnsureVBRMp3Sync.
* Added dotted lines at zero levels to view bias in Histogram(mode="stereo").
* Added TimeStretch(). This filter can change speed of the sound without changing the pitch, and change the pitch of a sound without changing the length of a sound.
Optimizations:
* SSRC now has aligned data (slightly faster and SSE ready).
* Added MMX optimizations to Overlay mode lighten+darken with opacity=1.0, with no mask.
* Added SSE float to int audioconversion.
* Added 3DNOW! optimizations to sample-type conversions int to float, and float to int. Much faster.
* Added faster MMX to Invert by ARDA.
* Added RGB24, YUY2 and YV12 MMX Invert() function.
* Added MMX/ISSE chroma convertion to Overlay with YV12 input.
* Added MMX function for Overlay(mode="blend"), when a mask is used and opacity = 1.0.
* Removed unneeded DevIL components
Bugfixes:
* Fixed: DirectShowSource properly releasing filters on unload.
* Fixed: ImageReader/ImageSource flipped error messages and info overlay.
* Fixed MergeLuma not always updating properly.
* AssumeFPS: Added sanity check to ensure that denominator isn't zero.
* Fixed Loop() when called with no video (stickboy)
* Fixed error not being thrown in Conditionalfilter on an invalid operator.
* Fixed crash on certain resolutions in Resize.
* Fixed linecount on multiline strings (Bug ID 989276]
* Fix VideoFrameBuffer cache corruption
* Fixed VideoFrameBuffer cache corruption during "Plan C" memory recovery.
* The problem with ApplyRange/Animate?'s inability to use functions that take no additional arguments should be fixed.
* Removed overflow bug in ssrc upsampler.
* Fixed Audio cache crash if no audio.
* Cleaned up ApplyYV12 in textoverlay.
* Fixed float audio in Dissolve.
* Fixed audiobits clip properties now returning bits and not bytes.
* Fixed ConditionalReader inaccuracies on integer interpolation.
* Fixed Mask() problem with footage with different pitches.
* Subtract now clamps errors instead of overflowing.
* Added specific (and simpler) stereo mode to TimeStretch - no more drifting.
* Made ISSE YUY2 HorizontalReduceBy2() more "safe".
* Fixed missing plane in TemporalSoften.
* Corrected some quirks in TemporalSoften scenechange on artificial sources.
* Fixed IsParityKnown() in avisynth.h - thanks to stickboy.
* Random in scalemode is not returning limit value - thanks you stickboy!
* Fixed: Trim audio could crash, if sample types were different.
* Fixed crash-on-exit in SSRC, if rateconversion was skipped.
* Fixed one frame missing in TemporalSoften.
* Fixed Trim audio crash if sample types were different.
* Fixed chroma moving half a pel in Overlay with YV12-input mode.
* Fixed minor glitches in audio cache (out of range requests)
Changes:
* DirectShowSource now requests interlaced material to avoid internal (crappy) WMV9 deinterlacer. (Thanks to Russel Lang)
* ImageReader/ImageSource now accepts relative paths in all configurations.
* Adjust audio length in SelectRangeEvery to match new video length.
* Updated installer.
* ImageReader: tweaked default parameters.
* ImageReader: made ColorBars parameters optional (like docs claim!)
* ImageReader: No more "Image not in range". First frame is ALWAYS frame 0.
* Updated SoftWire codegenerator to latest version.
* ImageReader: Static image support, Floating-point FPS, aliased to ImageSource, frames automatically flipped when necessary.
* ImageWriter: Optional "info" parameter to show filename.
* ImageReader / ImageWriter: All errors returned as text clips.
* AviSynth will longer resize to non-mod4 widths in YV12 mode!
* Dissolve can now handle audio input with different sample types.
* Dissolve now checks if samplerates are the same.
* Trim/Dissolve: Better error reporting.
* Updated DevIL libs; removed unneeded DevIL components; improved error reporting in ImageReader / ImageWriter.
* Updated Overlay(mode="multiply") to work more logical. Old functionality is no more!
* Improved error reporting in ImageReader/ImageWriter.
* DirectShowSource() is now a plugin, and is automatically placed in the plugin directory by the installer.
* Disabled avisynth_c plugin autoloading (no longer a compatible way to do so).
Download from the SourceForge Project page as usual!
stephanV
Posted: Sep 1 2004, 05:06 PM
useful links:
Posted: Sep 1 2004, 09:49 PM
GrofLuigi
Posted: Sep 2 2004, 12:08 AM
Congratulations and thanks to the developers!
GL
meilin
Posted: Sep 2 2004, 01:35 AM
thx!avisynth is a great tool
4 replies since Sep 1 2004, 03:31 PM Track this topic | Email this topic | Print this topic
